Results 1 to 9 of 9
Thread: Stacking beads
    May 2018
    the Netherlands
    Stacking beads
    Did some practice just to keep in shape.
    Quite happy with it. Half of the plate was done flat and the other half horizontal.
    1/8 7018
    Fronius Transpocket 180
    Kemppi minarc 150
    Esab powercut 400
    Mar 2015
    Re: Stacking beads
    Look's purtty. Now do some with the same hand traveling opposite direction. After that,might as well try other hand.
    May 2018
    the Netherlands
    Re: Stacking beads
    Quote Originally Posted by Jax View Post
    You're right, i have to practice that more because i'm not good with my non-dominant hand.
    Kemppi minarc 150
    Esab powercut 400
    Nov 2004
    Southern Montana
    Re: Stacking beads
    Just a suggestion... you might try moving your torch ahead a bit more on each puddle before introducing filler. It will make for a wider puddle profile (dimes). This is for appearance, only, and does not, necessarily, improve fusion, or weld strength. It took me awhile to learn the technique, too.
    What is the difference between flat and horizontal?
    Wow! After producing all of those beads you must have been out of breathe, and probably lost a couple of pounds, fulfilling your desire to stay in shape. (A joke.)
    May 2018
    the Netherlands
    Re: Stacking beads
    This was done with stick not TIG. But I'm flattered that you think it might be TIG. Stick like TIG.
    Flat is 1F/1G and horizontal is 2F/2G
    Kemppi minarc 150
    Esab powercut 400
    Jun 2011
    Texas
    Re: Stacking beads
    Flat is lying flat on the table, while you make beads going across it.
    Horizontal is when it's standing up on edge, presenting a vertical surface, and you make the beads going across it.
    By the way, one thing you might do, if you have a band saw, is cleanly cut across it in 2 or 3 places and look for cavities. There shouldn't be any.
    -Ruark
    "Become one with the puddle, grasshopper" - Welding Instructor
    Lincoln 3200HD
    Hobart Stickmate LX235
    TWECO Fabricator 211i
    Nov 2012
    new york city
    Re: Stacking beads
    for some real world practice try it overhead then go to restricted access.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Ct
    Re: Stacking beads
    3g, show us some 3g, that's the fun stuff
    Apr 2018
    TN
    Re: Stacking beads
    I can tell the top is the horizontal and I'm not supposed to be able to tell. It looks very good, but some small tweaks needed. It's better than my last run at horizontal though..... I rarely ever have to do it so not much practice with it.
    1957 Lincoln Idealarc 300 AC/DC
    2020 ESAB ES 180i MiniArc
    Lincoln Idealarc SP200
    Lincoln 3350 PAPR
    CK CK17FV
    CK CK9FV
Page generated in 1,634,496,640.45157 seconds with 12 queries
