Thank You all that responded with diagnostic tips, i truly appreciate the help. So, here is what i did, and i hope that someone else will be able to benefit from my response. I first released the cable tension and dunked the stinger in water, one tiny bubble came up then nothing when i hit switch. That told me i had no gas at the end. I removed and reseated the stinger in the machine, paying attention to depth as well as the electrical plug, all was like it should have been, still no bubbles. i pulled the rubber hose from the valve and put a test hose on it, dropped that hose in the water and have a super amount of bubbles, i replaced the hose from valve to stinger for good measure. So, at this moment i have either bad o-rings on the stinger, or the stinger itself is an issue. I appreciate your guidance, i had no idea where to start and the many kind souls here put me in the right direction. Next to devise a test on the stinger to see if it is somehow stopped up not letting gas flow.
