Page 1 of 4 123 ... LastLast
Results 1 to 25 of 94
Thread: Sharpening Tungsten
    Jan 2011
    Newtown sq pa
    Sharpening Tungsten
    Will a CBN wheel be okay for Tungsten. Witch I already have and could scrub it with soap and water to clean the steel out. Or just get a dedicated Diamond wheel.I have cleaned the CBN wheels before. I sharpen Wood lathe tools that are high speed steel and once in a while I clog it up with carbon chisels.I have a spare that I could use just for The Tungsten.It will save a few bucks if I do not have to by a Diamond wheel.Thanks Tony
    Feb 2015
    Re: Sharpening Tungsten
    Spend the money and get a diamond wheel if you plan to do much tig welding. You can grind with anything but the diamond wheel is going to be the best for tungsten.
    Nov 2014
    PDX PNW
    I think sand paper is cheap and quick
    Nov 2013
    Livingston, New Jersey, United States
    What great sand paper.
    JOHN
    Sent from my SM-T387V using Tapatalk
    A lot of times, I just use the angle grinder. Works fine. Don't inhale, eat, or inject the dust.
    CT
    I only grind my tungstens on a a belt sander. 100 grit and it is not dedicated. I chuck them up in a drill and slowly rotate them while grinding. They work fine. You really don't need a diamond wheel or dedicated anything.
  7. Likes welding1 liked this post
  8. #7
    Nov 2014
    PDX PNW
    Louie a beat up old flap wheel that was used on random stuff can make it difficult to get a nice sharp point on the end of the tungsten. And a good point is important for DC welding. I use flap wheel so maybe it’s different on a belt sander
  9. #8
    Pensacola , Fla
    I bought one of these and mounted it next to a standard wheel (both on at the same time) on a cheap bench grinder to sharpen tungsten. It gives a very smooth finish.
    https://www.ebay.com/itm/Fly-Shop-6-...cAAOSwvzRX167-
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  10. #9
    Sep 2015
    West coast of Florida
    Quote Originally Posted by tonylumps View Post
    Yes, I wanted to outfit my 6" bench grinder, but it seems these are mostly 8" wheels, very limited selection of grits for 6", if you have a source let me know
    Richard
  11. #10
    CT
    Moto, I can easily get a needle sharp point on the belt sander. Much more stable and controllable than a flap wheel. The belt sander is a cheap bench top model.
  12. #11
    Nov 2012
    Are you welding on the Space Station? Maybe building a nuke plant in your back yard?
  13. #12
    Nov 2014
    PDX PNW
    My buddy does the same thing as u with his belt sander. I just don’t have one yet
  14. #13
    SoCal-LA
    Belt sander is what I use. Wood, rubber, steel, alum, who cares, the belt sheds it off before I grind a needle sharp point on my tungsten.
  15. #14
    Bench grinder with a green wheel is standard practice in our local, unless you're doing power plant work. You can do 99% as good a job as with a diamond wheel... no drills required.
  16. #15
    Oct 2018
    E.A.A fly-in 2012. Lincoln booth. Tungsten was sharpened by hand on a bench grinder. Tig'd Aluminum with it.
    Good enough for the Mfg, good enough for me - although I did spin mine with a cordless drill.
  17. #16
    Mar 2005
    Under a Rock
    I bought a Tech-south tungsten grinder... LOVE IT.
    I get the same exact angle and point everytime.
    It wasn't cheap, but to me it's no different than buying any other tool for the shop.
    It works and it works well.
    to each his/her own.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  18. #17
    Nov 2014
    PDX PNW
    Yep that’s overkill right there.
  19. #18
    Nov 2013
    I've heard you can sharpen it with a torch is this right.
  20. #19
    Nov 2014
    PDX PNW
    U can do anything you put your mind to
  21. #20
    I use a harbor freight circular saw blade sharpening wheel, 4'' diameter. $10 regular and you can use a 20% off coupon . I just place it up against bench grinder 6'' wheel.
    https://www.harborfreight.com/replac...ner-98862.html
    Or you can buy the complete setup. https://www.harborfreight.com/120-vo...ner-96687.html
  22. #21
    Quote Originally Posted by johnrbauer View Post
    There's a product called ChemSharp, I believe. Supposedly smells nasty, but works. Nobody uses it if they don't have to as far as I know.
    Otherwise, no, putting a torch to a tungsten will just make it oxidize and burn off, same as running it against an abrasive until it gets red-hot.
  23. #22
    Sep 2016
    Times 2. I have one and I like it...
    Sent from my SM-G965U using Tapatalk
  24. #23
    East Tennessee
    Quote Originally Posted by p4nh4ndle View Post
    You can sharpen tungsten with a torch, I've done it and used it my fair share. Not the ideal way to sharpen it but when your in a boiler and you've got a torch handy it'll work in a pinch. I've passed x-ray welds doing it. Sharpening tungsten is a much over hyped task on this forum. It's not so much how you sharpen it but to get it like you want it. I work in nukes and all varieties of power plants and this isn't rocket science. I've run automatic orbitals for years and on those it does make a difference and the focus is consistency. For that a diamond wheel is king period. Who cares how you sharpen your stuff just do it and get back to welding children.
  25. #24
    Jan 2011
    Newtown sq pa
    Why do you ask that question.I will use the tig to incorporate it into my other lathe work I have 4 CBN wheels I do a lot of High speed tool sharpening for my wood lathe. When turning Acrylic you are at the wheel every 3 or 4 Min. or risk blowing the piece off of the lathe.I have a CBN wheel I could dedicate just for that. Now they say I do not need a dedicated sharpening system.I am confused now.
  26. #25
    Nov 2014
    PDX PNW
    Welcome to the forum partsguy
Page generated in 1,620,984,313.73407 seconds with 13 queries
