Ideas for MIG Welding AL with Lincoln Invertec V350 Pro/DH-10 wire feeder
3.9K views 7 replies 7 participants last post by  shovelon
I'm new to MIG welding and was hoping you guys could provide ideas or recommendations on what I should be looking at to MIG weld Aluminum with the MIG welder setup I just bought. I have a used Lincoln Invertec V350 Pro factory model (non-pulsed) power source and a Lincoln double head DH-10 bench wire feeder (the LN-10 is the single head equivalent). Although I won't be welding for a living, I plan to have a hobby metal shop for my retirement where I envision welding 3/8" thick aluminum and sometimes 1/2" or larger.
I was hoping you could throw out some ideas on this post and then I can research the proposed product and/or solution for addition to this MIG welder.
#3 ·
"Although I won't be welding for a living, I plan to have a hobby metal shop for my retirement where I envision welding 3/8" thick aluminum and sometimes 1/2" or larger."
What the hell sort of 'hobby welding' do you plan using 3/8-1/2" or thicker AL? And, it looks like CEP is 'cheating' by demonstrating the use of 4043! One HAS to suck lung fulls of 5356 smut.....
#4 ·
Isn't bigger always better? Who knows what type of welding I'll be doing in the future, but I should note that I have a small farm, a sawmill operation, and various pieces of heavy equipment (stock trailers, tractors, backhoe, a couple big trucks). I'm an engineer by trade so who knows what hair-brain fabricating idea's will come out of my noggin in the future.
A couple of weeks ago, I rented a somewhat low aluminum trailer to pull behind my jeep so I could haul home an 800 lb wood boiler . I chained the winch to the side pockets (something like 3/16 or 1/4" thick) on the AL trailer. While winching the boiler up the incline, the aluminum pockets on the side of the trailer started to bend. I learned that although aluminum is light, it isn't very strong.
#6 ·
I have VERY little experience with MIG aluminum. I have owned a spool gun for my Millermatic 252 since 2013. I haven't had occasion to plug it in.
When I explored the concept of aluminum welding, a salesman convinced me to buy a spool gun. He demonstrated. It was OK, not impressive.
Before that, I asked a friend who had bought an outfit if I could try his. He bought his to build custom truck beds. He sort of built one. I tried on 16 gauge alum. to build a simple box. I keep that mess around to show how far I have come.
Now you want to see me get excited about aluminum welding, lets talk TIG.
I believe MIG should be used for 1/8" thick, and greater. TIG is good for all thicknesses.
#7 ·
That's a Very nice system. If it was Pulse it would be golden. That was one of the best Lincoln units. You can find a spoolgun for it for not much money and get started there. Many many options as you move up in equipment from there.
#8 ·
I have few questions. Does the operator manual have any parameters for welding alum?
Are you open for using 5356 filler 3/64" diameter(which is what I use for heavy plate 6061-t6 and feeds wonderfully)?
If it were me I would start with U groove drive rolls and a short torch and nylon liner. See if it even starts and maintains an arc.
