Results 1 to 4 of 4
Thread: TIG 200 Issue
    Jan 2019
    TIG 200 Issue
    I've been using the Tig 200 for a year without any complications, and the machine has worked well.
    One day to the next, without changing any of the settings I cant get the puddle to stabilize. I add filler material but it wont stabilize or travel when I move the torch.
    I've replaced all of the consumables, including the torch body itself, swapped out a new bottle of argon, and even had the machine itself inspected and diagnosed and the warranty center said it was fine yet I'm still having the same issue. I'm welding stainless at between 110-140 amps and have tried changing the gas flow but it hasn't helped at all. Anyone ever had this issue or have any possible solutions? Stumped here.
    Re: TIG 200 Issue
    Post pictures of your welds. I can't help you since I don't have the experience yet, if ever, but someone who can will want to see what your welds look like.
    Primeweld TIG225ACDCP
    Lincoln Power Mig 210 MP
    Lincoln SquareWave Tig 200
    Miller Spectrum 125c
    Oxy/Acetylene
    Optrel e684, Lincoln 3350, Speedglas 9100xx, Klutch 800 Series
    Lathe and Milling Machines
    Jan 2019
    Re: TIG 200 Issue
    First picture is what they normally look like, second is with the problem I'm having.
    Nov 2012
    ROCKVILLE ,,VA
    Re: TIG 200 Issue
    looks cold, turn heat up
Page generated in 1,713,291,630.28164 seconds with 19 queries
