Results 1 to 16 of 16
Thread: Looking for a quality electrode holder that doesnt come off the lead
    Jan 2019
    I have been having trouble with my electrode holder coming off of the lead, but the electrode holder I bought to replace it because of this problem is worse about it. what electrode holders and leads do you guys use, and how do you connect them so that they don't come apart?
    May 2010
    ct.
    Re: Looking for a quality electrode holder that doesnt come off the lead
    That’s an unusual problem.
    Is the welding lead too small for the clamp?
    A pic of welder,cables,electrode holder might
    be helpful (and/or interesting).
    400 amp Bernard short stub and
    tong type holder that came with Thunderbolt
    work fine for me on both#4 and #2 cable.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
    Another thing that pulls cable out of the handle..…………...pulling your leads around by the stinger. Tempting when you're in a hurry, but will work the cable loose over time.
    Jun 2016
    Back to the jungle
    I’m glad you posted that. It’s such a common sense thing I wouldn’t have even thought to mention it.
    Too often we assume a faulty product is the cause of our carelessness.
    Dec 2008
    Part of the problem is the set screw doesn't grab all of the strands of the cable.
    I like to cut a piece of copper tubing that just BARELY fits over the cable strands then tighten the whole assembly under the set screw.
    I also agree with what Farmersamm said. When you need to move hold the stinger in one hand and grab the cable with the other!
    Jan 2016
    northeast USA
    Quote Originally Posted by rexcormack View Post
    well you just found your problem, most if not all electrode holders come with that copper piece you want to make, maybe it fell out of the bag when you opened it up, but that is your answer...
    Jul 2018
    Cumbria, UK
    yeah you need that copper piece. even a bit of steel will do.
    Nov 2012
    new york city
    this! the duro type holder use to come with a piece of curved copper for fitting between set screw and stripped cable. now i just use a piece of plumber's copper tube. i worked with someone that silver soldered the cable into the holder socket but to me that's kind of drastic.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Mar 2009
    I like to put a little dielectric grease on the allen screw and give it a good bull hunchin’.
    Aug 2012
    AR
    I use a piece of copper tubing and one of those swage tools to seat the cable in it, then the set screw fits really tight and the swaged end won't come loose as easy.
    I make my own crimped fittings to add a little strain relief to my ground clamp connections. Sort of the same scenario as electrode holders.
    They’re not idiot proof, but then again I never drag cables around by pulling on the clamps or rod holders.
    Apr 2012
    socal
    I cut a longish strip of copper flashing (from a rich folk house!), clean it, & wrap it around the strands two times or so.
    Much more flexable than copper (plumbing) tube.
    Works for me.
    What is the sound of one knee jerking?
    Nov 2012
    If your cable is small, you can always fold it over before you put it in the holder.
    Dec 2008
    It was in the new stinger but was very thin and flimsy!
    Copper tubing worked much better.
    Been doing that for years.
    Jun 2016
    Back to the jungle
    Dunno. When I arc or tig the lead is wrapped once around my forearm. The grounds give me fits sometimes.
Page generated in 1,627,391,661.04323 seconds with 11 queries
