3phase to single
4K views 20 replies 5 participants last post by  Kevin_Essiambre
cutmaster 120 followed directions in manual but getting a fault. unit does not have multi voltage power power selector switch on back of machine. Any ideas ?
#3 · (Edited)
Did you add the jumper to contactor? Main wire going has a flat jumper connector that goes from #1 input to #3. Been a while but you have to have that jumper installed to get the 1/3 phase units to work. All the multi-voltage /phase machine have a low/high voltage switch on the back of the machine.. Wonder if you have a 600 volt unit only? Have to look up the model #, and it will clear it up.
#4 ·
manual said add 2 jumpers. I also read that only the US models have that switch ? used machine just got it , it was wired for 480 3ph.not familiar with 600V model , woiuld that be over seas version ? fault is ; red fault light with 65psi lit as well
#5 ·
All I know is my 82 came as a 3 phase layout, had one jumper in the side panel for single phase use.. If you change one more jumper I don't remember, but only the one was needed to add to the machine.. Try here.. He was a Esab tech, Thermal rep, and now back at Esab again. He knows Cutmasters.. You will get better info then I can provide..
Gene.Wright@esab.com
#8 ·
So.... if yours doesn't denote a '1' phase does it even have the grid to the right of that that shows the current draws for both 1 and 3 phases... but probably minus the '1' phase blocks?
Sounds like it may only be a 3phase machine... not sure of the internal differences could be just a different input board or same board minus a few components or something like that....
#12 · (Edited)
As per jimcolt's (plasma guru extraordinaire) many posts on the subject in countless forums.... He recomends 2X the current max. draw of plasma for the phaseconverter capability.
edit: and this is with a rotary phase converter. I don't know if a static converter would/will work on the a120... hopefully jimcolt will pop in and lend a bit of knowledge :) although with out 'Plasma' in the title he might not...
#15 ·
Depending on how much you're gonna use it, you could always just buy a 3 phase generator to use for power. You can find generators cheap all over the place. Just an idea. But if you're gonna be using it every day or a few days a week it's not practical.
Sent from my SM-G920W8 using Tapatalk
#17 ·
It will draw 128 amps of 240 volt single phase power..(measured in my shop) Just so you know it will take a warp drive to run it.. Call Gene above to get the final answer..
