Results 1 to 25 of 29
Thread: Tweco Fusion MIG Gun
    Aug 2016
    Florida aka The Gunshine State :)
    anyone happen to know if a Tweco Fusion MIG Gun will fit the vulcan series mig welders ?
    i am considering buying the vulcan omnipro 220 and i happen to have a Tweco fusion 220
    new in the box.
    When i grow up i want to be a welder
    PRIMEWELD TIG225ACDCP
    Millermatic 215
    Everlast PowerPlasma 50
    oxy/ac
    Not enough talent to use any of it very well
    Sep 2005
    Cave Creek AZ
    Re: Tweco Fusion MIG Gun
    Doubt it. What back end does the gun have?
    Aug 2016
    went to HF last night and took pics of the vulcan gun
    here they are
    and here are the pics of the tweco fusion 220
    they look damn close but i didn't take a caliper to measure the vulcan as a comparison
    Millermatic 215
    oxy/ac
    Delaware
    The main thing is to make sure the argon grove lines up and the o-rings seal.
    Aug 2016
    im in the hazard fraught quite often. i'll carry a dial caliper with me the next time i go. yup, I'm one of the old crusty type that prefer a dial caliper to the new fangled digital crap.
    I trust the analog way more than the digital and it don't need batteries.
    Millermatic 215
    oxy/ac
    Mar 2014
    I know pics can be deceiving but it looks like a Tweco copy. Only thing is the brass end of the liner looks thicker. Yeah, you'd be wise to take a caliper with ya.
    Dec 2016
    i know the tail end on vulcan stuff is the same as a tweco gun #2 on a hobart hefty suitcase.
    Aug 2016
    Quote Originally Posted by filetobeef View Post
    i think the fusion is different than the #2 because it uses those captured contact tips that have no threads on them. But
    the tail end may be exactly the same.
    Millermatic 215
    oxy/ac
    Mar 2014
    There's your answer. All you're really concerned with is the power pin end.
    Dec 2016
    only difference is my older twecos use 1/4" spade connectors for the trigger instead of the pigtail with connector,but the tail has the exact same dimensions and fits and seals perfectly.
    Jul 2018
    Beavercreek, Ohio
    Take your gun with you to HF and see if they'll let you plug it into the floor model?
    Gregg
    Hobart Handler 210 MVP
    Hobart Stickmate 210i
    Jul 2016
    Midwest
    It should be plug and play on the Vulcan. That's the standard Tweco back end that many companies copy and I know someone who just did opposite of what you are wanting to do and the Vulcan gun fit his TA 211i. What you need to check is if the Vilcan trigger wire amphenol is 4 socket with 2 pins. I think the Fusion comes with a 9 socket with 2 pins. As long as you hook the 2 wires together the trigger will work. jus check the amphenols. The back end will fit.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
    Aug 2016
    Quote Originally Posted by Rangerhgm View Post
    I'm guessing thats not going to happen. The 220 at the HF has the door bolted down so you can't open it.
    what i can do is take the tweco and calipers to HF and do the measurements
    Millermatic 215
    oxy/ac
    Aug 2016
    changing the trigger amphenol would be no big deal.
    thanks for the conformation. the tweco is a spare i had for a TA 211i
    Millermatic 215
    oxy/ac
    Apr 2016
    CA
    What happened to the 211i?
    Aug 2016
    i sold it and bought the miller 215.....DUMB move...But i can't undo it.
    Millermatic 215
    oxy/ac
    Apr 2016
    CA
    How would you compare the two against each other? Just curious to hear from a user that has used and owned both machines.
    Aug 2016
    not being the most experienced welder ( just a hobbyist ) the miller auto set ( i thought ) might resolve the issue with the thermal arc units having to be dialed in almost perfect. Once you wonder from those almost perfect settings, it get out of control fast.
    Jody at welding tips and tricks gave the same report on the fabricator series. the display is not very accurate on the fabricator series just complicating things. can you imagine how it would be for the not so experienced welders
    if Jody has trouble with it ? On the flip side, the auto set feature on the miller SUCKS OUT LOUD. For the most part its 2 settings too hot. i did read somewhere that miller designed all the auto set features for a T-type fillet weld.
    So i find that using the auto set feature is not a savior. i usually either just turn it back 2 thickness settings for the material I'm welding on or just turn it off and go manual.
    Dont get me wrong, it welds fantastic when its set right. But it damn sure does not weld good enough to justify the cost just because its blue. I just bought the primeweld 225x this morning
    and will be selling the miller 215 multiprocess that does not do AC and considering buying the vulcan just for mig use.
    Millermatic 215
    oxy/ac
    Apr 2016
    CA
    Thanks for your perspective on things. I guess I am lucky to have the trim dial on the Rebel in the advanced features used in Smig mode that allows me to adjust the heat a little up or down from with in the auto settings
    Apr 2016
    CA
    I couldn't find anything earlier but low and behold this showed up out of the blue while I was looking for music vids. Go figure. Any way it's a decent vid that shows the Rebel's advanced tweaking abilities Enjoy.
    Aug 2016
    you have that exact option on the miller 215 also
    Millermatic 215
    oxy/ac
    Aug 2016
    you can adjust both slopes on the miller 215 - voltage and wire speed slopes. gotta admit i never seen anyone using 4T ( aka cruise control lmao ) on a mig. i guess it would be nice on super long welds on clean prepped material.
    Millermatic 215
    oxy/ac
    Dec 2015
    I also had a difficult time trying to dial in a 211i and sold it...lol And that Tweco gun and tips were mad annoying. The contact tip would fall off when I pulled the nozzle to clean it. Id have to make sure I held the tip vertical so it stayed on the wire. I replaced it with a Bernard unit. I cut the Tweco connector and spliced it onto the Bernard. You will probably have to splice the connector off supplied gun onto your tweco but should work fine.
    Millermatic 185
    Lincoln Ranger 305G
    Victor O/A
    Aug 2016
    Quote Originally Posted by Mcm308 View Post
    yeah, I'm not a big fan of that tweak gun either because of the contact tip crap. they just built it like that so they could sell proprietary contact tips.
    but, I'm sure its better than the gun that comes with the vulcan mig
    Millermatic 215
    oxy/ac
    Jul 2016
    Midwest
    Quote Originally Posted by bevis28 View Post
    Actually, I looked at the Vulcan gun and it's similar to what Lincoln uses and or used on their SP135 style units. Takes tweco front end and it has Tweco back as well. I'm also not a Tweco Fusion fan.
    Cobra Pythons
    Victor Gas Apps.
Page generated in 1,624,259,846.76897 seconds with 12 queries
