Results 1 to 10 of 10
Thread: Mystery tool
    Mar 2008
    Georgetown, Texas
    Mystery tool
    Does any one know what this tool is? It's made by Starret and about 4" long. The little pin part turns and every revolution moves the dial one of the little line.
    Apr 2017
    Re: Mystery tool
    Revolution counter
    Re: Mystery tool
    Shaft speed indicator... I've got one too. You time the revolutions with your watch for a minute to determine RPM's. Newer versions use a little rubber knob on the end to keep it spinning at shaft speed, but that one will work great for finding drill speeds.
    Cut 50 Plasma
    Apr 2010
    Re: Mystery tool
    Bob
    Speed indicator . . .
    Quote Originally Posted by henry42 View Post
    Revolution counter
    AKA ='s RPM . . .
    Opus
    Re: Mystery tool
    I use a tire valve cap on mine since the rubber cap disappeared long ago. Must be placed at the center of the rotating shaft. Shafts that are center drilled are easiest.
    ---Meltedmetal
    Sep 2012
    Utopia,TX / Pasadena, TX
    Re: Mystery tool
    Tack is right, haven't seen one of those in many moons.
    Mar 2008
    Georgetown, Texas
    Re: Mystery tool
    Thanks guys, I appreciate it.
    Outside of Raleigh, NC
    Re: Mystery tool
    They were originally used to determine the RPM’s of the old hit and miss engines.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
    May 2010
    ct.
    Re: Mystery tool
    Bob
    AKA ='s RPM . . .
    Opus
    If I remember correctly,Starrett calls it a speed indicator,although
    it indicates revolutions, not revolutions per minute. As Whtbaron
    mentioned, you need to use it with a timepiece to determine rpm.
    Seems primitive now that you can buy a cheap laser tach for
    about $15. I remember an older co-worker (tool and die maker)
    having one of those old indicators in his toolbox. Never saw him
    use it. It’s one of those tools I don’t need, but would like to have.
    I have an old mechanical tach with a cup for reading rpm and a
    wheel for reading fpm.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
    Apr 2010
    Re: Mystery tool
    jpump5
    Quote Originally Posted by jpump5 View Post
    If I remember correctly, Starrett calls it a speed indicator,although it indicates
    As whtbaron mentioned, you need to use it with a timepiece to determine rpm.
    You are correct - and I stand corrected . . .
    I have only held this tool 'in my hands once' thirty-five years ago . . . and no
    one knew what it was . . .
    http://americanhistory.si.edu/collec...ct/nmah_690549
    Upon this read - I gathered it was a tool used by 'A Walker', or an 'Operational
    Foreman'
    to keep the machine 'in their charge' running within perimeters? -
    jpump5
    Thanx - for your focus - in telling what this tool actually does . . .
    Opus
Page generated in 1,624,025,037.36810 seconds with 12 queries
