Results 1 to 9 of 9
Thread: Plasma Torch type..ATC or RPT
    Feb 2019
    I thinking of buying a Thermal Dynamics 60i plasma cutter. It looks like you can either get it with an ATC or RPT type torch. Does anyone have an opinion about which they would get and why? Thanks.
    Jan 2005
    Re: Plasma Torch type..ATC or RPT
    Link on the RPT machine.. Never seen one.. I bet you can only get the 60i with the ATC connection. Part # of the RPT machine would help,, If you want to add length,have the torch removable from the machine, use a SL-40 torch, and a SL-100SV torch then a ATC is what you want..
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    Thermal Drag-gun 35C
    INE 1500
    Klutch 140i
    Delaware
    Quote Originally Posted by mccorb View Post
    I think you mean a SL, MC or RPT style torch. The ATC is how you connect the torch to the plasma cutter. The SL are the Thermal Dynamics torch,s. The MC are the Radnor (Airgas) torch's. The RPT are the TEC.MO torch's.
    Apr 2016
    CA
    mccorb Can you provide links to the 60i with both options of torches.?
    Apr 2016
    CA
    I think I figured it out. There is a RPC but it is not a torch but rather a torch pendant type trigger to operate the torch manually so you can have a torch in use on a table or cutting tracks and start and stop the torch cutting by sqweezing the trigger on the RPC pendant.
    see pic below:
    Mar 2014
    Was just looking on ESAB's website and all I can see them listed with are QD torches aka TD's ATC connections. Like Brand X said, you'd definitely want the quick disconnect, makes swapping, extending, or working on your torch a whole lot easier.
    Just watched the video, ESAB has one-upped TD's ATC feature by designing the torch so you can completely disconnect the entire torch head and handle assy by simply unscrewing it from the cable. Sweet
    Feb 2019
    Here is the link...
    https://mam.esab.com/assets/1/BDBA5C...et_Main-01.pdf
    So once you figure things out, explain it to me please. I've never had a plasma so I don't know what's important so far as torches.
    Delaware
    I guess I am blind as I see no reference to a RPT type torch in that link.
    Mar 2014
    The only "choice" you have in the torch is whether you want a 20' or 50' torch. They both have a 75* head. The only "choice" you have with the plasma is whether you want a single phase or 3 phase power supply. Assuming you're going to be hand cutting. All are quick disconnect torches.
Page generated in 1,635,009,252.25606 seconds with 12 queries
