Results 1 to 8 of 8
Thread: VFD Programming help 3 phase drill press conversion
    Have a 220 3 phase motor trying to get working. The wiring is easy. But when I turn it on the motor sounds like its spinning up, but is not moving. Sorta a noisy type of sound, more vibration type of sound. VFD is a cheap A2 series, the typical ones you see on ebay. Went though the programs didn't change much. should I change all hthe 400hz to 60? sems the videos I have watched leave these alone
    If you can offer any assistance that would be great.
    Dec 2015
    Re: VFD Programming help 3 phase drill press conversion
    Yes, back the top end setting down to 60 hertz. Run 0-60 to change speed.
    May 2010
    ct.
    Quote Originally Posted by MountaineerMiner View Post
    That 400hz. may not be the max. speed.
    400 hz. is a common switching for vfd’s.
    Is vfd set to produce 3 phase? Sounds like motor may be
    “single phasing “.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
    Dec 2015
    Quote Originally Posted by jpump5 View Post
    “single phasing “.
    Jpump5 May be correct, I am not an EE. My experience has only been running both low and medium voltage motors on VFDs at work. In my personal shop I have numerous Vfd drives, all of which I have set up for 60 hertz max. The only motors I have been around that run on 400hertz are the cheap Chinese spindle motors. I suppose there are other applications that run on 400hertz, I am just not familiar with them.
    My advise to the OP is try setting to 60 hertz and see what happens, my guess is it works , but again jump5 sounds too be much more informed.....
    Jun 2008
    Was the drive new or used? If used it's time to read the programming manual & check the parameters that have been set by the prior user.
    Dec 2016
    what was the same??
    if you revive a 3 year old thread,contribute quality info if you can.
    Jan 2020
    Did you enter the motor name plate data, if so, it could be a switching freq. issue and you could quieten it down with a adjustment in the motor control parameters. Just a thought. You may call the Mfg and get customer service to help. Good luck.
    Sep 2016
    Detroit, Michigan
    Quote Originally Posted by Bob-O View Post
    This thread is two years old and only revived because of a spammer.
    http://mivise.com
    Everlast PowerTig 210EXT
Page generated in 1,624,501,730.85112 seconds with 11 queries
