Results 1 to 24 of 24
Thread: Tig Flow meter ball
    Pensacola , Fla
    Tig Flow meter ball
    Ok I need some clarification on one thing, the ball in the flow meter. when setting the flow and you are setting to the 15 cfh mark is this with the top of the ball or the bottom on the mark
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
    Nov 2014
    PDX PNW
    Re: Tig Flow meter ball
    It won’t matter. Timmy says more is Better so go with the top bar
    I always read the ball flow meters at centerball.... unless marked differently like shovelon says.
    SoCal-LA
    Victors are always top of ball. Esab is usually top of ball and says so on the globe.
    Pensacola , Fla
    Well thanks but after some more research ronsii gets the star mid ball is what was in the docs from the flow meter's manufacture.
    But I'm sure like many things it may be brand specific
    Hypertherm 65
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
    I just remember it from an old school guy giving me tips 25-30 years ago. Not really sure how much difference it makes anyways when you look at how precise or not these are
    Nov 2014
    PDX PNW
    I put the bottom of the ball where I think 11 is on my flow meter, works good with my 5 cup.
    Feb 2009
    Chicago
    Most imports are middle of ball
    Look on the back of it on the tube, some will tell you where it’s calibrated at
    Hypertherm Powermax45
    Esab ET220i
    Razorweld 195 Mig
    Razorweld 200ac/dc Tig
    Tormach 770, Tormach xstech
    Carbide3d Nomad3
    Sherline 4400 CNC Lathe
    Apr 2017
    Measure at the torch if you're that concerned about the actual flow rate.
    Jun 2011
    Aiken SC area
    I'm with Henry on this one. But, we're assuming the hand held unit is accurate. Food for thought. Bob
    Pensacola , Fla
    The only concern was using to much gas
    Hypertherm 65
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
    Nov 2014
    PDX PNW
    Use a 5 cup then. There the best and easiest to weld with. I stuck my tungsten out about 5/8” or more the other day no problem on stainless
    Pensacola , Fla
    Thanks for the info
    Hypertherm 65
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
    Dec 2003
    Fairfield,CT
    Mine is printed on my flow meter glass in super small writing. I just wrote is out where I can read it in magic marker. "Center of Ball"
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
    Long Island
    I too always turn it to 11.
    Jun 2016
    Back to the jungle
    Well Tom. If it's an old flow meter the ball hangs a lil lower
    I was expecting bonzo's reply a lot sooner ��
    Pensacola , Fla
    new flow meter old welder and there hanging low
    Hypertherm 65
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
    city of Four Flags
    Quote Originally Posted by rlitman View Post
    Why would you want a flow meter to go one louder!
    Nov 2012
    u mad, bro?
    Dec 2016
    old welder with no flow worth measuring no matter ball height.
    Lol
    Feb 2012
    This has been brought up in the past.
    What I want to know is , do you use the top or bottom or center of gauge mark when using top, bottom or center of ball?
    I use center for measuring always because most gauges I've ever used are made for mid range. Nonlinear gauges , still use center of needle/marks. Some machinists can reaptably measure down to two thousands eyeballing. I've been able to do five thousands of an inch on a good day tho
    Nov 2014
    PDX PNW
    I measure better with my finger
Page generated in 1,713,280,842.16380 seconds with 18 queries
