Results 1 to 25 of 36
Thread: Welding Helment
    Oct 2018
    Welding Helment
    What kind of helmet should I get? Thanks!
    Sent from my LG-M430 using Tapatalk
    Nov 2012
    new york city
    Re: Welding Helment
    Quote Originally Posted by WeildingKidd14 View Post
    if there was a prize for vaguest first post this might take it. how about a few particulars like process,lens preference,price range,ect,ect.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Sep 2015
    SE Pa
    Re: Welding Helment
    Welding helmet would be my choice
    Oct 2018
    Re: Welding Helment
    I stick weld, and I want to get a bigger view field so it's easier to see what I'm doing. I would prefer a cheaper helmet with good quality than a expensive one that I don't like .
    Re: Welding Helment
    Then I would stay away from the expensive ones you don't like.... I found the HF /generic chinese ones to be decent and you can usually find them on sale for 30 bucks or so.... But I do like the HTP one I got the Striker Supreme for under a 100 bucks
    Oct 2018
    Re: Welding Helment
    Thanks, I will check them out
    Re: Welding Helment
    [QUOTE=ronsii;8695109]Then I would stay away from the expensive ones you don't like....
    Hooker 101...
    Re: Welding Helment
    Lolrof
    Re: Welding Helment
    Jackson Truesight……………………..like watchin' yer favorite porn in HD
    Jun 2016
    Back to the jungle
    Re: Welding Helment
    Gots all them buttonz and stuff.
    Get a pipeliner with a flip down lens and an Arc One auto darkening lens.
    That's what Noah used on the ark. I know. I'm so old I was there !
    Re: Welding Helment
    [QUOTE=WeildingKidd14;8695105]I stick weld, and I want to get a bigger view field so it's easier to see what I'm doing. I would prefer a cheaper helmet with good quality than a expensive one that I don't like .
    Cheaper is not better. Your best bet is to test drive the helmets . There is a reason why the expensive ones are better. I don't know anyone that bought a expensive one they didn't like . That's why you try before you buy.
    Post your location and there maybe a member near you who's helmet you can try. Come by me and you can try my older Miller Elite. I waiting for a better rebate on the Miller clearlight models.
    https://www.millerwelds.com/products...ens-technology
    Jan 2015
    Lewis Center/Powell Ohio
    Re: Welding Helment
    You'll cuss up a storm if you get a static lens, have to flip it down while holding the rod in the right spot. Get an auto dark hood. The HF lower priced ones are "OK" but you can't see real well out of them unless you're in quite a bit of light.
    When mine died, I got their Vulcan hood and the difference is HUGE! Still a HF hood but compares almost identically to high priced Lincoln, Miller hoods. Big lens. You can actually see what you're doing with it. It fits really, really well once you spend the time to get it adjusted to you. I have a cheater lens in mine because I have old eyes. It worked fine without but it's way better with the cheater.
    Re: Welding Helment
    A fixed lens helmet will work. It certainly won't stop you from welding. I went back to a fixed shade last year. I still use auto in the field...til it dies.
    Feb 2011
    Southeast Louisiana
    Re: Welding Helment
    I too have the Vulcan and would recommend it highly. Where did you get the cheater lens if you don't mind. Do they only make the smaller ones ( 2 X 4 ?) and not one that would cover the whole large area?
    Hobart 190 mig
    Lincoln/Century 140 mig
    Lincoln buzz box
    Chicago Electric cutoff saw
    Lotos LTP5000D Plasma Cutter
    HMC Swivel head band saw
    Jan 2019
    Tucson Arizona
    Re: Welding Helment
    save phace
    http://savephace.com/Welding/EFP-Helmet
    I have the high dollar one at $170 cause I don't like outside controls and do like 4 sensors but they can be had as low as $49 for the more basic AD hoods
    all my other helmets including miller, jackson and htp are hanging in net in shop trailer for assistants to use or as backup in case I accidentally run over my Save phace helmet as thats about what it'd take to kill it...
    net on left in front of ladder is where other helmets live now ..Save phace is on hook in helmet bag between torch cart and wall so its protected and fast at hand
    Jan 2015
    Re: Welding Helment
    Quote Originally Posted by cabranch47 View Post
    I got one online somewhere and got another one at Menards. Only the 2x4's are available. No one makes them for the entire viewing area.
    Feb 2011
    Southeast Louisiana
    Re: Welding Helment
    Thanks for your reply concerning the cheater lens.
    Hobart 190 mig
    Lincoln buzz box
    Jan 2019
    Tucson Arizona
    Re: Welding Helment
    BTW, here are some pics of my SAVEPHACE helmet, they do have largest viewing area (the area around the lens is a fixed tint) same headgear as the Millers etc.. and they do accept a cheater lens
    like I said thing has totally replaced my others, am ordering a second (camo wasn't my preference they were sold outa everything else when I ordered it for the top end ones)
    Sep 2014
    texas
    Re: Welding Helment
    I'm going to have to stop by over at Savephace and see if I can demo their hoods. My 15+ year old Miller still works, but it's nowhere near as clear as a couple of newer hoods I've used.
    Jul 2018
    Beavercreek, Ohio
    Re: Welding Helment
    I've been pleased with my Eastwood L6700. Very clear view.
    https://www.eastwood.com/eastwood-la...met-l6700.html
    Gregg
    Hobart Handler 210 MVP
    Hobart Stickmate 210i
    Feb 2019
    Re: Welding Helment
    Quote Originally Posted by USAWELD View Post
    Why buy a big window to shrink it down to 2 X 4?
    Peripheral vision, I'd say is one thing you can never have enough of.
    Jun 2017
    Southern California
    Re: Welding Helment
    HTP also has the Striker XXL which has one of the largest viewing areas on the market. But of course I am biased. That being said, if you are going to be using a magnifier buying a large viewing area helmet is wasting money. The only size the magnifiers are available in are 2 X 4. Why buy a big window to shrink it down to 2 X 4?
    https://www.usaweld.com/Striker-XXL-.../90131-xxl.htm
    Does this helmet have the feature that allows you to weld facing the sunlight? Like in a garage with the door open? Thank you
    Jun 2017
    AJO, ARIZONA
    Re: Welding Helment
    My problem has always been from the sun shining in the back of my hood.
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    JEFF
    Re: Welding Helment
    Same here... I've taped a cloth to the top of my hoods to drape over the back of my head before. Only some of my cheaper import hoods have a problem with the sun in front of them.
    Laredo + Midland/Odessa
    Re: Welding Helment
    I'd say it's all in the sensitivity setting of the helmet. This is my HTP Striker CSV facing direct sunlight. As you an see by the shadow, the lens hasn't darkened, so the adjustability is there.
Page generated in 1,713,262,588.97812 seconds with 19 queries
