Hi Guys,
I've got a firebox here I need to repair a crack on, I was wondering with constant heat cycles in mind which would be a more appropriate approach;
Pound the cracked area flat and weld a new plate right over it with a lap weld, or cut a square out and weld a plate in level with a butt weld?
Any preference to rod? I think at the moment I only have 6011s on hand. I will make sure both metals are cleaned/bright before starting.
Thanks in advance as always!
Josh
Josh
