Results 1 to 13 of 13
Thread: Welding Table Clamp
    Welding Table Clamp
    I have a bunch of cheap drill press clamps that I never use. Today I decided to cut the threaded portion off one.
    Drilled a 5/8” hole in a piece of flat bar.
    Cut a short length of 5/8” round stock.
    Welded round stock into the flat bar hole.
    Welded assembly onto base of DP clamp.
    New clamp in use on welding table with 5/8” holes.
    I use this same concept with sliding bar clamps.
    Sep 2015
    West coast of Florida
    Re: Welding Table Clamp
    Looks good! I did something similar for my acorn table, using F style clamps
    Richard
    Website
    Jul 2018
    Cumbria, UK
    nice one.
    I did similar for mine - actually bought 8 cheap visegrip type clamps and chopped the bottom leg off. As well as a few F clamps.
    Fredericksburg, VA
    Great idea Terry. I have several of the same clamps and one of these days I am going to thread a piece of 5/8" bar stock and turn the clamp into a holdfast for the anvil.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
    Good idea. Pat beat me to it about using one for anvil. I did see one for anvil using the screw half of a Pony pipe clamp. It was a '' U '' shape that fit the hardie hole and a wedge was placed inside the ''U'' for securing.
    Fredericksburg, VA
    Thanks Bob.
    I am debating whether to thread a plate and then weld it to a piece of square stock for the hardy hole or just a piece of round bar for the pritchel hole. Other than finding the time to do it, it is easy enough to do both.
    I was also debating the idea of making different shaped pads that can slip on to the end of the clamp to hold different material. I was thinking of a larger flat pad, a piece of angle with the "V" pointing down for round stock, etc. That is an idea that Terry may find useful
    Millermatic 252 MIG
    Speaking of anvil hold downs, here’s one I made using an old tire wrench.
    This pic shows the “v” notches I cut in the wrench head
    If you look close you can see the bushing I use when dealing with a thin 3/8” table top.
    It drove me nuts thinking I needed to achieve the just right angle when bending the tire wrench. I couldn’t get the damn thing to hold. Took me a while to realize I was hitting it TOO HARD!
    All it requires is a LIGHT tap with a hammer to set and a slightly heavier tap to loosen. What a dumazz!
    Here’s a better pic of the extended reducing bushings I made for using on thinner welding table tops.
    Thanks, tackit. The cast iron pipe I managed to get from one of my friends doing a big civil water line project. Not often you find a crop with the “bell” end.
    I have a feeling they may have cut a chunk off the end of a new pipe for me. I didn’t want to ask...
    Feb 2014
    n.w. of chicago
    That's ductile iron I never tried welding to it myself, what did you use, I've used NI99 and bronze rod on regular sanitary cast iron, nice looking project
    Welding Table Clamp
    Yes. It’s ductile iron and I didn’t do any welding. I filled it with rebar and concrete and left 4 studs for the top. The side brackets were drilled and bolted.
    Feb 2014
    n.w. of chicago
    Nice, sorry I'm looking on a old phone and don't have Internet, now I waited for the pictures to show up clearer, real nice
    Welding Table Clamp
    Thanks , pat h
Page generated in 1,713,267,366.60786 seconds with 18 queries
