Results 1 to 2 of 2
Thread: Powermax 45 question can cpc port be added later ? Is there a model for 230V 3 phase
    May 2018
    Considering buying a powermax 45.
    I dont need a cpc port right away, but who knows in the future.
    Can the cpc port be added later if i need it ?
    I guess these are the two models to choose from
    Standard power supply230 V CE/CCC 088130
    Power supply with CPC port and voltage divider 230 V CE/CCC088131
    The 400V 3 phase models, can they operate at 230V 3 phase ?
    Oct 2007
    New Hampshire, North Carolina
    Re: Powermax 45 question can cpc port be added later ? Is there a model for 230V 3 ph
    Yes, a CPC / voltage divider harness (part number 428653) can be easily added at any time. The amperage draw is relatively low with the 45xp, so you can run it off a single leg of 3 phase power between 200 and 240 volts. Jim Colt
Page generated in 1,624,495,145.00392 seconds with 11 queries
