Welding Wire Lube Cleaner?
3.4K views 11 replies 9 participants last post by  123weld
Does anyone know what ingredients are in welding wire lube and cleaner......silicon???
#9 ·
Worst thing I ever did was use lube on the wire. If not kept wet the lube clogged the liner. Finally got fed up and bought a new liner and blow it out once a year and all is good.
#12 ·
lol, i believe it. i bought a 5 pack, used one, and never used the other 4. that innershiled wire is really dirty
#11 ·
I only use solid wire and have always used the felt folded over the wire and fastened with a large butterfly paper clip. Never use flux core, I figure if I need to weld outdoors stick will work just fine.
Mike
