Results 1 to 6 of 6
Thread: Lincoln Port-A-Torch Oxy Tank Certification???
    Jun 2008
    Wisconsin
    So got my Lincoln O/A Port-A-Torch setup today. The acetylene tank is DOT certified and the Ox tank is ISO 9809-1 certified. No DOT. Am I going to be able to get the Oxy tank exchanged???
    Regards,
    SnyperX
    Lincoln 140HD
    Lincoln/Harris O/A
    Jun 2008
    Wisconsin
    Re: Lincoln Port-A-Torch Oxy Tank Certification???
    Damn, nothin? Really?
    Regards,
    SnyperX
    Lincoln 140HD
    Lincoln/Harris O/A
    Dec 2008
    ISO is backward compatible to DOT.
    Any welding supply that knows which way is up will not even blink.
    I bought the same torch outfit and my local welding supply swapped the cylinders without question.
    Jun 2008
    Wisconsin
    Quote Originally Posted by rexcormack View Post
    Perfect!! Thank you. I basically have AirGas and Praxair here in the Madison, WI area. While a couple of welding shops also, but pretty sure they just use AirGas and Praxair for their supplies.
    Regards,
    SnyperX
    Lincoln 140HD
    Lincoln/Harris O/A
    Jun 2008
    Wisconsin
    Well I ultimately was able to swap the tanks for $34 for both. Not bad.
    Regards,
    SnyperX
    Lincoln 140HD
    Lincoln/Harris O/A
    Jul 2016
    Midwest
    Quote Originally Posted by Snyperx View Post
    Great newer family / veteran owned welding supply in Madison = Mississippi Welders Supply. Great company. Give them a try.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
Page generated in 1,664,157,921.14331 seconds with 11 queries
