Quality light / medium duty Oxy-Acetylene regulators
4.8K views 11 replies 7 participants last post by  danielplace
Hey all, I am attempting to improve my current Oxy-Acetylene setup. I have a Victor Journeyman kit which is ok, except the regulators and gauges perform poorly at low pressure (I sometimes use a micro torch for silver brazing) What I mean by poor performance is, getting precise pressure requires multiple iterations of adjusting regulator, tapping the crappy gauge over until I am convinced it is what it says it is (?) in terms of actual pressure output.
Can anyone recommend a regulator set with high quality to improve upon what I am experiencing? I am not expecting it to cover use with cutting torch, just normal light to medium duty welding and brazing.
BTW, I am putting the gas rig back into service as I am now off-grid and still lacking power required to run my Synchrowave 250. It's a perfect opportunity to polish my gas welding skills !
Thanks
-Jeff A
#3 ·
Using my Smith Little Torch with Purox regulators isn’t exactly ideal,
requiring some readjustment. I notice regulators are available for the
Little Torch (from Guesswein and probably others) and assume they’re
better suited to the low pressure requirements of the small torches. I
personally would rather deal with the readjustment than buy, store and
deal with another set of regulators.
I wonder if the problem is more in the gauge than the regulator, and
maybe using gauges with less span would make adjusting for the
Little Torch easier, while still providing enough oxygen pressure to allow
me to use the cutting torch.
#5 ·
I think its two things: first a lot of the regulators that come with torch sets are single stage, meaning as the pressure in the gas cylinder drops, you need to readjust the pressure delivered to the torch. If you want to avoid that, you need a two stage regulator. However for most torch uses this is not really needed. You may be able to get by just replacing the low pressure gauge with something like this if you don't use the regulator for oxyfuel cutting. https://store.mathesongas.com/very-low-pressure-gauge-brass/
#6 ·
My low press. oxygen gauge is 0-200 psi. If I remember
correctly, the Little Torch is looking for ~1 or 2 psi.
A 0-50 oxygen gauge would still allow me to cut, and I think
it would be an improvement when using the Little Torch.
My current procedure for setting the oxygen pressure for the
Little Torch is to get the needle just off the stop pin at 0.
#7 ·
Thanks all for your input ! I think I will try changing out the gauge first. I looked at the link those are VERY low pressure gauges indeed - then I found this puppy
https://store.mathesongas.com/low-pressure-large-dial-gauge-brass/ but I have yet to read all the fine print to see if it is compatable. I will also check out what Detroit Torch offers.
Thanks againn.
-Jeff
#12 · (Edited)
Now your talking. Was thinking to suggest the same a while ago. Didn't want to bust the budget.
Drink the Blue Coolaid baby.
Don't buy just the regulators as they cost nearly as much as a whole kit right now with the $40 off the set with the NON-Lifetime torches. They are like $260 minus $40 rebate. $220 is a deal. Sell everything else but regulators for $120 and you got your 30 series regulators for $50 a piece. You can't hardly buy Harbor Fright crap for that.
Even better $250 minus the $40. https://store.cyberweld.com/smith-toughcut-welding-outfit-mb54a-510.html
