Results 1 to 10 of 10
Thread: Landfill save 225ac
    Apr 2008
    NW ON Canada
    Landfill save 225ac
    Was at the landfill the other day and had to drag this home.
    Needs a power cable, leads, power switch and cooling fan motor.
    Just did a fast search for the Colling fan motor and power switch. I think purchasing the parts I need to get this running will cost me more than what the machine is worth?
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    Aug 2019
    Re: Landfill save 225ac
    First off, I would make a make shift safe power cable, by pass the missing switch and see if it makes power first before spending any money on it.
    Give it a nice paint job and put it out as "Yard Art"
    Apr 2008
    NW ON Canada
    Quote Originally Posted by astronut View Post
    Yes. That was the plan. This is how it was last being used. Power switch was bypassed.
    Jason
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Mar 2009
    Yeah just the power switch is high dollar. But I’da drug it home too.
    Jan 2015
    Lewis Center/Powell Ohio
    Obviously someone before you came to the same conclusion. Man that thing is ugly. I would have sent it to the landfill too.
    good you saved it even if it doesnt work you can paint it up and keep in your garage for a conversation piece. bypass the switch to see if it works.
    tell us if you get it working
    I had a Hobart with similar output values except 60% duty cycle. It was in perfect condition. At $100.00 I advertised it, made sure word got around. There was 0 interest except one question "Will it MIG weld?"
    I ended up scrapping it. Removing the copper was more work than the copper was worth.
    Apr 2008
    NW ON Canada
    It does work. I got the cooling fan freed up by spraying the bushings multiple times and rolling the fan over. The fan is working as of now. The unit does power up and strike an arc. I have a disconnect switch in my 220v power plug in my shop which is nice since the switch on the welder is bypassed. It will need a new switch though before I gift it to a family member.
    Jason
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    It’s such a shame scrap metals are hardly worth the effort and or cost of fuel to turn them in.
Page generated in 1,713,295,144.51915 seconds with 20 queries
