Cut the slot in a bigger width piece after hole drilled, then mill the sides of the track to desired thickness. Try to mill that slot when the piece is to size, and all's ya gonna do is tear up the side walls...…..not enough support for the cutter radial forces...…….go big, then mill down from outside of walls.
