Hello everyone looking for a few answers. I welded for many years when I was younger, stick welding in construction, then later mig welding in industrial. with mig I was used to using volts. This machine has wire speed 1 to 10 and volts 1 to 10. I have measured the volts while welding max 24.5 and a max wire speed measured at 275 ipm. The welder runs very good, but im new to flux core, and that's probably what I will stay with, as im not welding that often. Im running 035 wire my question is 275ipm enough for 24.5 volts. And what ballpark amps would that be at max setting. And if it's not should I step up to 045 wire? and thanks in advance for your help.
