Results 1 to 25 of 40
Thread: Engine welder generator question
    Nov 2015
    As I am watching the news about the power outages in California, I am interested in setting up a backup generator for my house. We don't have natural gas at the property so propane or gasoline/diesel.
    Now the exciting question is to get an engine welder that can be used as a generator in an emergency. The house main panel is 150A so 18kW is the peak usage, but in a pinch we can do probably with ~12kW.
    Any suggestions? Would a Trailblazer 325 do? Other recommendations? Thanks.
    HTP Invertig 221H w/ CK20 water cooled torch
    Hypertherm Powermax 45XP
    Optrel Crystal 2.0
    Jul 2011
    Bossier Parish La.
    Re: Engine welder generator question
    My house has a 200 amp breaker panel, yet I can power most of the house with my 8KW Bobcat 225. So you may be able to get by with less than a 12 KW unit. The only thing mine won't pull is the outside AC compressor. Everything else it can handle, including an electric clothes dryer while washing a load of clothes, so that means running a 240V well pump, too. I connect mine by way of a manual buss transfer switch.
    May 2010
    ct.
    I bought the Hobart at Tractor Supply. Rated 11kw peak.
    10 kw .$2900 before tax. Similar to Bobcat without CV.
    Wanted back-up power and an excuse to have an engine
    drive welder. Welder works well. Haven’t needed back-up power
    since I bought it.(of course).
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
    CT
    That trailblazer is going to run at 2400-3600 RPM. Unless you have a very specific need for an engine drive welder, I would think you might be better served by an 1800 RPM diesel generator. something like this.
    http://www.centralmainediesel.com/or...sp?page=1250TS
    It has 33-60% more fuel efficiency that the trailblazer when used for auxiliary power (1.3 gph versus 0.7 gph at half load), and slower turning diesels can run longer between maintenance windows. I am sure it will run your invertig. Plus the trailblazer isn't a true 12KW generator. it is 10.5KW unit that can surge to 12KW for short periods of time.
    Sep 2016
    Detroit, Michigan
    No argument that a diesel prime power generator is better than something like the Bobcat, but you're talking almost twice the price.
    I suspect most fairly normal houses can get by on 10Kw if they don't try running a large AC unit. We have a 20Kw standby Generac on natural gas that can power everything, including a 4 ton central AC unit, but that pushes it close to the max.
    http://mivise.com
    Everlast PowerTig 210EXT
    Northern Cal., Shasta County
    I can run my small 1200 sq ft house easy off a 7500 gasoline. No air conditioning tho, propane hot water, swamp cooler & propane heat. Fridge, and freezer and all the lights you want. Electric dryer makes the genset moan a little if other things are going at the same time. I can see where a family with all electric everything could have a hard time with anything less than a 7 or 8 kw. Multiple members can make it tuff to control what all goes on at one time. Us two old folks are kinda synced up on what can and can't be done at the same time.
    Hair dryers, vacuum cleaners, dryer, electric hot water, electric heat, freezer kicks on, fridge kicks on, lights on in every room,,,,,,,,,, things a family has to think about. I know a few families where 'thinking' just isn't part of the dailey routine.
    Quote Originally Posted by koenbro View Post
    I doubt you ever get even close to that. Try this. Look at your electric bill for how many kWh you use in a month. Divide that figure by 720 to get your average kW usage. Multiply it by say 5 and that should cover your basic needs (assuming you don't normally do a lot of aluminum welding during blackouts).
    Just because you have a 150A panel doesn't mean you use 150A continuously, or even ever. Service here is 200A but average usage is about 0.5 kW or 4A.
    If you get a generator and find that it isn't big enough, you can always turn off the HW heater as needed, or weld less aluminum during blackouts.
    CT
    More expensive for sure but not 2x the cost. List on the trailblazer is right around $6K. That Isuzu 12KW I listed to is $8.4K before add ons. A 10KW Kubota diesel is $6.5K before add ons. The trailblazer really isn't a 12KW unit,
    Sep 2016
    Detroit, Michigan
    By the time you can actually use the diesel generator you're going to have between $9K and $10K in it. Just adding a fuel tank you'll be at $9K. So fine...$6K versus $9-10K. At the very least you're talking 50% more.
    I didn't say the TB was a 12Kw unit, I said most people can probably get by with 10Kw. Seeing as how the OP is in Phoenix I would suggest a careful load study being really honest. If the power goes out in August he's going to want the AC going!
    http://mivise.com
    Brethren, Mi
    I bet its better than 12K. Maybe not continuous ,,, maybe,,, but welding machines got lots of poop and are heavy duty. I have a little Lincoln 210, 16 hp single cyl rated at 6000 generator, starts a 5 hp motor.
    Just as an aside note; in this area up here one zone was out for 56 hours, another 60 hours and one 88 hours. Some on the other side of the valley may have been more or less, not sure. At commiefornia gas prices long outages can get spendy. Of course loss of food in the freezer can get spendy too.
    My 302 Trailblazer runs everything I need in my house. As mentioned at full load you could use a gallon of gasoline a hour.
    A dedicated generator will be more economical for sure.
    My 251D gives 26A / 3kW and I suspect you could run it for several days before you'd need to add diesel fuel. 3kW is a bit light for a whole house, but in an emergency where you just wanted to keep your head above water, you can run the fridge and a few other things for 4 hours, then run some other things for 4 hours, lather rinse repeat...the machine sips fuel and never breaks a sweat (runs at 1850rpm all day every day, regardless of load, gotta love diesels)...
    Jul 2011
    Bossier Parish La.
    But a dual purpose machine, welder/generator is easier to justify the purchase of over a one purpose (generator) machine. Having an engine drive welder you can take anywhere you need it, to use for what ever welding job that may come up, may make more sense in the overall scheme of things, too. Why limit yourself to a one trick pony? Although I admit, I also have an 8KW generator that can supply back up power as much as the BC can. The BC is an 18 HP unit and the generator is 16, so not a LOT of difference in fuel consumption over the long haul, but a BIG difference in what it can be used for.
    Mount Tabor VT
    I'm a dealer for Generac standby generators. I use at home a Miller Bobcat 250. It has output rated at 10000. Correct me, but Trailblazer has two alternators, One feeds an invertor it is three phase. The other alternator is single phase with lower output rating.
    NEC requires your automatic generator to be large enough for automatic load. If set up is manual, no requirement for automatic load.
    Numerous customers do OK with 5000 generators. Obviously, a 10000 will provide more comfort.
    If you have a well, a furnace, air conditioning, refrigerator, maybe a septic pump, and sump pump, you can function in an emergency if they work, but they don't need to work all at once. Alternating loads is the key.
    Jul 2011
    Bossier Parish La.
    I agree with you Willie, most home stand by generator dealers want to sell the most high $$ generator they can for your home. So they total up the entire electrical load of the entire house and spec the generator to power EVERYTHING at 100% power all the time, when you rarely NEED 100% power in most cases, on a continuous basis. When running on backup power you should pick and choose what is the priority things to power at the time.
    Nov 2015
    We have 3 ACs, two for the house (35A each) and a 24K BTU Mitsu minisplit for the garage. Obviously if the power were down in the AZ summer, I would not run the garage minisplit (nor would I weld) or the pool pump, just focus on keeping the house comfortable. Fridge, freezer, range are another 30A tops, but cooking would be only intermitent. So bare minimum is about 80A, and 100A tops is what I am thinking.
    Very useful advice above guys, thank you all. Am moving away from a trailblazer due to cost, and favoring a Bobcat 250 EFI. Can always use it in the field if ever needed as a welding source -- to power the Invertig as a stick welder.
    Checked he Honda generators but they don't offer 10KW -- the one they do is for standalone industrial applications and needs special ways to connect to the house. Seeing how sought-after are the old Lincoln engines, I am hoping that the Bobcat would keep its value.
    Optrel Crystal 2.0
    Oct 2009
    Austin TX
    Harbor Freight has their 9000 watt generators on sale for about $650 that have, I think, a 13 hour run time on a full tank of gas. I use one on my boat dock to raise and lower the boat. Then I have the Bobcat 225g as power backup for the house. Have never had to use it, but I have been wondering if the 8000 watt Bobcat would run the 4 ton Lennox AC system since it is one of the newer soft start compressor/blower units, that slowly build up to speed.
    Miller Syncrowave 350
    Millermatic 252/ 30A spoolgun
    Miller Bobcat 225g w/ 3545 spoolgun
    Lincoln PowerArc4000
    Lincoln 175 Mig
    Lincoln 135 Mig
    Everlast 250EX Tig
    Century ac/dc 230 amp stick
    Victor O/A
    Hypertherm 1000 plasma
    Jul 2011
    Bossier Parish La.
    That just doesn't make any sense to me. Why not just stick weld with the BC and leave the Invertig at home? The BC can also be set up to TIG weld if you need to do that, too, and it can wire weld with a spool gun attached to it.
    Aren't some inerters also kinda finicky about the AC input they get, too? Seems like I heard that somewhere (don't own any inerters so take it FWIW)...
    CT
    This is why I would go with a dedicated diesel generator. Fuel economy matters when you are out for a week or more. Noise also begins to be a factor after a few days (speaking from experience after Sandy)
    Mar 2005
    Under a Rock
    HUHH??
    I find it very hard to believe a Diesel generator is less noise than a propane or gas job.
    although it would be nice to run it off my home heating oil tank.
    also, Diesel generators are NOT cheap$$
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Outside of Raleigh, NC
    In my hurricane and ice storm area, for years I have used my Trailblazer Pro 350D as backup power for my house. It has worked great. 12KW of power, and I have it sitting on top of a 66 gallon auxiliary tank on my welding trailer for 71 gallons of total fuel capacity. Typically I am powering the house on generator 3-5 times a year, every year. Sometimes for just a few hours, other times for a few days. I live on a farm in a rural area, so there are lots of times that a store will bring a tree down on the lines somewhere.
    My home has a gas (propane) stove, water heater and furnace. Main electrical consumption is the 3 ton air conditioner, followed by the electric dryer.
    The trailblazer has pulled the well pump (3/4HP 200' submersible), the air conditioner and ceiling fans, etc and we've been quite comfortable during outages. With its Kubota diesel, it has been quite reliable and it has powered the house through outages lasting 2-3 days on more than one occasion. At the same time it is pulling two refrigerators and a chest freezer
    Personally, from a budgetary standpoint I like the idea of having one piece of equipment that serves multiple uses, as opposed to having to spend money on multiple pieces of equipment that don't get used every day. Mine is set up on a trailer so it's doesn't take much time to pull it over and plug it in.
    Last year I picked up a good deal on a low hour used 17KW propane generator, and last month we finished installing a 200A automatic transfer switch on the power feed to the house. Hopefully in a few months I'll finish running propane lines and add a second tank so that if I'm gone and the power goes out the system will fire up and transfer over automatically, saving my wife the hassle of hooking up a manual generator.
    Personally I think that you're on the right track. If you are operating a welding business, you have the added benefit of depreciating the welder / generator; whereas with a dedicated house generator there is no write off.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
    Jan 2019
    Tucson Arizona
    Arizona is NOT California.. yet (let a few more relocate cause they can't handle the stupid high taxes and enviro insanity and yet they keep voting for demecrates and we might be california) here in AZ an particularly in Phoenix area we don't see the power outages like they have there... most of californias outages are the result of liberal policies taking priority over common sense...
    If we do have outages here its usually during monsoon season and then only if ya are like me and live out in the country where some power lines are above ground and prone to poles falling or getting hit by a drunk etc... so realistically the TB will probably never get used as a generator... however its a good excuse to use with the other half to justify buying it!
    Jul 2011
    Bossier Parish La.
    Quote Originally Posted by monsoon-mech View Post
    But it's a nice peace of mind knowing when the power DOES go out for whatever reason, you are prepared and set up to deal with it properly, IN ADVANCE. Having the other half's approval keeps thing smoother at home, too.
Page generated in 1,620,984,675.85313 seconds with 12 queries
