Results 1 to 17 of 17
Thread: Workshop from scratch
    Jun 2019
    I am moving into a new place that doesn't have a garage, so unfortunately I am going to have to design and build a small workshop for myself. I am asking for ideas.
    Currently I am thinking of a shop the size of 2 car garage, with a 3rd room in back that is as wide as the 2-car garage.
    The 2-car garage with be divided, separate rooms, each with a garage door:
    1. One side for wood and sawdust with a dust collection system
    2. The other side will be a metal and welding shop
    I want to have a covered concrete slab in front of the garage doors so that I can open the garage doors and work outdoors, even in the rain.
    The 3rd room in back will be a clean work space with heating and cooling , and a large sink. A toilet would be nice, but I won't be able to tie into the home's sewer system.
    110/220 v outlets, of course. And lots of overhead lights.
    The property has 200 amps, what circuit breakers should I have in the breaker box?
    No windows, for security.
    Any other ideas?
    Mar 2008
    Georgetown, Texas
    Re: Workshop from scratch
    What state are you in, Harry?
    Jun 2019
    West-by-God-Virginia
    Where couples can still remain brother and sister, even after they divorce each other
    Apr 2016
    CA
    Burgalar bars over windows can add security so you can open windows for cross breeze and less noise pollution in the shop from loud exhaust fans etc.
    What types of projects will you be working on or how big will they be. Any need for taller doors and ceiling?
    Quote Originally Posted by Harry Marinakis View Post
    LOL!!!!! Nice
    Maybe some high windows so peeps can't just browse what you have in there. Skylights are nice for daylight also... and by the sounds of it you'll have everything you need to be comfy so a fridge would be cool.
    Jan 2011
    W. Wisc
    You've got a great start. Make it as big as you can afford, and then a bit more. I don't know that you need to fully wall off both front stalls, but it isn't crazy. Sometimes it is nice to have the open space. I put a bench in between my 2 garage doors. very handy - you would have a wall there. All depends what you want and need.
    Insulate below the slab and put thick poly down to reduce moisture migration. I recommend radiant heat tubing in the floor. Can't put it in later and you never have to connect it if you don't want and all for only a couple hundred $
    -Dave
  7. Likes whtbaron liked this post
  8. #7
    Jun 2019
    I 'd rather have no windows than a place that looks like a prison. Pillbillys around here are always looking to steal something that can be quickly turned into cash, so they can buy more oxy pills. They'll steal your change jar but leave the $100 camera sitting on the counter.
    All of my work is small stuff. Given that I'll have garage doors, I think that regular doors everywhere else will be fine.
  9. #8
    Sep 2016
    Near Traverse City, Mi.
    Make your doors wider than normal.
    Miller Dynasty 280 DX, Lincoln 210 MP
  10. #9
    May 2016
    Idaho
    Harry, I did something like what you are describing. I prepped the slab in the machine shop side so it would be 7" thick where a 2-post hoist was installed. It has paid for itself many times. Consider you need 12'-1" ceiling height. I don't have covered area in front, but a shed roof on each side.
    My welders are near the garage entry and and I only installed one 220v 50 amp welder circuit so need to switch plugs between machines. Not the end of the world, but would be nice to have at least one more outlet. Another mistake was only running 10ga. wire to where the compressor is located which limits me to less than a true 5hp motor. two other other 220v 20 amp circuits cover lathe and milling machine. I ran several 220v. circuits in the wood shop but still end up sharing a plug in with a band saw and wide belt sander.
    A floor drain was installed so the parking area immediately inside the OHD drains to the center and not to the corners or up against the door. Probably not a concern in your location but much appreciated where snow and ice is the norm. Enjoy the journey.
  11. #10
    Jun 2011
    Aiken SC area
    Harry, if your new shop will be a steel building with regular roof, not rounded, sky lights make a real savings on electricity during daylight. Also as stated above, pouring a 7 to 8 inch floor on one side for a lift down the road will pay dividends later. Just some thoughts. Bob
  12. #11
    Jun 2019
    Great ideas everyone. I am writing all of this down.
  13. #12
    Jun 2019
    Update
    Well, the pandemic really quashed construction progress, but my custom-built shop is about 95% complete after about 18 months of slow construction.
    The pandemic also drove up construction, labor, and material costs.
    1200 square feet
    Radiant floor heating
    Air conditioning
    Humidity controlled
    Three separate rooms
    200 A service
    About 25 electrical outlets, 20A, 30A, and 50A
    Lights on circuits separate from tools
    R19 insulated garage doors
    Heavy steel side door (it's a fortress)
    Covered outdoor work areas in front and along the side
    French drains all the way around
    I have yet to build the four 2' x 8' x 8' storage cabinets, and the sink area
    I'm installing the dust collection system now.
    Two 15' x 25' rooms up front
    A 15' x 30' room in the back
    Lots of juice and outlets
    Night lights
  14. #13
    Mar 2008
    Georgetown, Texas
    Looks a little different but is the prettiest shop I think I've ever seen.
  15. #14
    Brethren, Mi
    That is pretty.
  16. #15
    Jun 2016
    use plywood for walls and ceilings and then paint bright white. the plywood lets you hang stuff heavier than drywall can hold. install more outlets than you think you will ever need. grinding and metal shavings will rust on the concrete that gets rained on or wet. hang a curtain in-between stalls so you can open up area and make it 2 stall size if need be or collapsable panels.
    lincoln 125sp
    dayton 250 ac/dc
    miller 211 w/spool gun
    ahp 200 sx tig
    lotos ltp5000d
    kubota b3200 FEL BH
    of course duramax diesel
  17. #16
    Quote Originally Posted by duramax-rob View Post
    You're a little late.... he's already got it built with interior metal laid sideways on the studs with the partition in between stalls. Scroll up....
    city of Four Flags
    That's a fine looking shop!
    I like that it's separated side by side, ie wood working side, steel working side.
    You may find that using French cleats on the walls make hanging stuff easy and modular.
    The horse is out of the barn but I always use out swinging doors.....can't kick those in!
  19. Likes Roert42 liked this post
Page generated in 1,713,274,603.33443 seconds with 20 queries
