Page 5 of 15 FirstFirst ... 34567 ... LastLast
Results 101 to 125 of 355
Thread: Oh, Why Not
  1. #101
    Re: Oh, Why Not
    Anyways, it really machined pretty nice, even with the out of round wear. Kept it around 120rpm due to the interrupted cuts. Worked out ok without destroying an insert.
    Name:  broken wheel63.jpg
    I was concerned about brinelling the bearings due to the pretty hefty clamping force to keep everything tight, and locked up, inside the hub. Looks as if I got by without any damage.
    Name:  broken wheel64.jpg
    Other than some odds, and ends...……..that's about it till the end mills get here. Coulda just driven in to get them......gotta drive over there to get a 5" mic
  2. #102
    Re: Oh, Why Not
    Had some time to work on the thing yesterday.
    I need to make a template in order to bore the stud holes to size. The bolt pattern is 6 on 6.
    Name:  broken wheel66.jpg
    I'm not a math guy by any means. Just ain't my thing. But I did find a very good tutorial on YouTube.
    Good simple way to do things using two right triangles.
    Anyways...………………….set my dividers.
    Name:  broken wheel67.jpg
    Starting at one point, and walking the dividers around the circle, center punching each point as ya go.
    Name:  broken wheel68.jpg
    Works great if you get your punch marks dead nutz on the line/intersection
    Name:  broken wheel69.jpg
  3. #103
    Re: Oh, Why Not
    But not so great if'n ya don' hit yer mark
    Name:  broken wheel70.jpg
Size:  126.1 KB The one on the right side of the line was the first attempt. The one on the left side of the line was the second attempt.....the punch slid off the "hill" and wound up somewhere in the South 40 )
    All, in all, it's a pretty good method for laying out the pattern. But it isn't spot on...………………..I was about the diameter of one punch mark out of tolerance when checking the pattern by walking the dividers around the circle using the punch marks.
    While the diameter of a punch mark ain't a killer (this ain't the Space Shuttle), I'm not sooooper doooooper pleased with it. Any slight error on ANY of the punch marks compounds itself as you progress around the circle.
    Gonna pop it on the rotary table to check the accuracy, and probably actually wind up using the rotary table. I didn't wanna mess with the rotary table because it involves making a stinkin' fixture to hold the dam plate to the stinkin' table
  4. #104
    Re: Oh, Why Not
    [QUOTE=farmersammm;8726747]But not so great if'n ya don' hit yer mark
    Have you tried auto center punch ?
  5. #105
    Re: Oh, Why Not
    [QUOTE=BD1;8726748]
    Yup, that's the way to go. I don't punch any thing until the dividers walk it out right after a couple of tries.
    Seems to me that a short set of divider legs (3-4") are usually more accurate.
  6. #106
    Re: Oh, Why Not
    Hell, I was doin' pretty good till the last hole
    Didn't get a chance to put it on the rotary table, had to move 40 bales today. Got guys cryin' to get the hay off their place. Idiots don't seem to realize we've had a weekly rain storms. I'm workin' in a muddy mess, and still got mud holes where I'm dumping. I tore up the doods driveway today, maybe that was a little lesson for the guy Got 64 (one 40, and one 24)more to haul. Be the usual drill...…….they regret the pissed off attitude once I come in and trash their place. My favorite is when they dig a trench with the tractor trying to push the bales on the trailer. Ground may look dry after a week, but it's mud underneath.
  7. #107
    Feb 2019
    Snyder TX
    Re: Oh, Why Not
    You can "walk" your punch mark to center. Hold punch at a 30 degree angle towards center & use light blows to walk it over, then one good blow at 90 degrees & your golden.
  8. #108
    Jul 2016
    SE New Mexico
    Re: Oh, Why Not
    Quote Originally Posted by cwby View Post
    That works.
  9. #109
    Re: Oh, Why Not
    Throw in a pair of good eyes,, and I ought to be better at it Only see clear out of one eye these days...……..sucks!!!!!!!!!!!!!!!!!!!!!!
    Speakin' of eyes...…………...I've been eyeballin' one of those slender "precision" punches. The one I use is a squatty thing with not very much ground angle at the point. Hard to actually see the tip.
    Anyways...………..on with the comedy movie!!!!!!!!!!!!!!!!!!!
  10. #110
    Re: Oh, Why Not
    After last afternoon's bale fiasco...…….I decided I'd had enough, and spent the evening cooing on the couch with K'kins
    Name:  broken wheel71.jpg
Size:  105.2 KB Bales sat in water, got soaked, and flat on the bottom. Dumped ok when I had a slight incline to the right side of the trailer, but crapped out on me when the trailer was just slightly more level side to side Didn't have the heart to tell the guy to roll them before he loaded them.....poor dood was on the verge of a heart attack anyways.
    Made some fixtures for holding the plate on the rotary table.
    Name:  broken wheel74.jpg
    Name:  broken wheel75.jpg
Size:  132.1 KB The little blocks will come in handy when it comes time to bore the holes in the wheel disc.
    Used the Uranus Penetrator () Marketing guys thought that name would be a sure fire seller. Easy way to find rough center, only off a few thousands.....about .004 to be exact. My collets leave a lot to be desired, but they's paid for.
    Name:  broken wheel72.jpg
    Made final dialing in a breeze.
    Name:  broken wheel73.jpg
    On the centering tool...…………..The mill has about .0005 runout inside the bore. An end mill, held in a collet, has about .0025 runout at the collet.....same with a good quality ground HSS tool blank, and it increases the further down ya go...…..to about .004. I figure that's about normal for a machine of this nature. Gotta probably spend the big bucks to get tighter. .004 at about 4" below the collet is ok in my book, all things considered.
  11. #111
    Re: Oh, Why Not
    Used the wiggler to center the plate up. Some things you can buy import, but these gotta be Starrett...….they're the only ones that will actually spin true.
    Name:  broken wheel76.JPG
    Now it's sphincter time Did the manual layout really suck as bad as I thought it did?
    Name:  broken wheel77.jpg
Size:  92.8 KB The scribed line is out by about the thickness of the scribed line (We're assuming the leadscrew is accurate on the mill)
    Name:  broken wheel78.jpg
    Name:  broken wheel79.jpg
Size:  67.1 KB These aren't the best, or the worst...……...they're the average as ya go around the circle. If a guy only used the manual layout, he'd be pretty close to the ballpark.
    The Mother Of All Clusterf**** was a clusterf*** as expected But if a guy eyeballed it, he'd still be confident the stupid wheel would fit the hub.
    Name:  broken wheel80.jpg
Size:  88.0 KB Sorta looks like the Moon
    So...…………..if'n the boys at NASA call ya to do a job that's called out within half a dimple...………………..you're ready to rock without the fancy rotary table
  12. #112
    Re: Oh, Why Not
    Now...……...about that high fallutin' rotary table...…….
    I didn't know what was good or bad, when I bought this stuff...…………..just figured it would come in handy one day. Day I bought the mill, I had doggone near a pickup truck full of stuff that I thought I'd need one day. Checkbook was bleeding when I left the store.
    This is an unacceptable Vernier IMHO...…………………………………..
    Name:  broken wheel81.JPG
    Had I known better, back then, I'd of looked for a table with 10 second divisions, AND DIALS WITH BETTER MARKINGS.
  13. #113
    Re: Oh, Why Not
    Pushed the bales off the trailer with the t bar thingy I made years ago. Usually use it to push stuff off a flatbed trailer with the loader. Anyways...…...you can never have enuff stuff
    Name:  broken wheel82.JPG
    Name:  broken wheel83.JPG
Size:  221.0 KB Then, it's off to grab another load.
    Got back,, and started in on the template again.
    Leetle holes......Name:  broken wheel84.JPG
    And the bigger hole that will become center for indicating on the faceplate when the inside of the template is bored to size.
    Name:  broken wheel88.JPG
  14. #114
    Re: Oh, Why Not
    Or you could go to Shoup and buy exactly what you're building for $20 each.
    https://www.shoupparts.com/RR6600-6-...forcement-Ring
  15. #115
    Re: Oh, Why Not
    Quote Originally Posted by Oxford1 View Post
    Those would be great if the hub wasn't ruined to some degree, and the offset needing adjustment. The real work is in the template (templates). The center discs are gonna be plug and chug. You'll see the need for a template when I get back to work on it.
  16. #116
    Re: Oh, Why Not
    The Comedy continues
    I'm not able to comfortably use the faceplate. The parts are just a bit too small in one dimension for good clamping, and a little large in diameter for clamping that'll allow turning the outside diameter.
    So...…...another (of many) fixture thingy.
    The bar that will hold stuff in the 3 or 4 jaw.
    Name:  broken wheel89.JPG
    I used an annular cutter, but was surprised at the taper it cut. Almost .0015 .
    Name:  broken wheel90.JPG
    Name:  broken wheel91.JPG
    While it ain't a Disaster Of Monumental Cosmic Consequence...…….it's a problem This is gonna be a shrink fit connection.
    Cleaned it up with a die grinder, and a very fine stone.
    Name:  broken wheel92.JPG
    Name:  broken wheel93.JPG
  17. #117
    Re: Oh, Why Not
    The pin was turned to about +.0025
    Name:  broken wheel94.JPG
    And...….Sammy discovered the magic properties of ScotchBrite
    Name:  broken wheel95.JPG
Size:  194.5 KB Name:  experimental layer copy.jpg
    The center hole in the pin wasn't used to turn the piece. Its sole purpose is to make it easier to rough in the adjustment when mounting this thing in a 4 jaw.
    I've never done a shrink fit, so I'm a bit unsure of myself when it comes to dimensions. I'm at about +.0025 total interference.
    I'm relying on Machinery's for the fit tolerances.
    This is a 1.132ish diameter pin where it connects to the bar...……………..
    Name:  broken wheel97.jpg
    I'm aiming for an FN4 fit, which is specified for parts under a large amount of stress. In this case...…...this pin's gotta resist the torque when something is mounted on the bar, and turned to size.
    Name:  broken wheel98.jpg
    I feel that increasing the interference will distort the bar, and possibly cause it to yield...……..thereby taking the ooooomph out of the fit...…….you're counting on the bar to apply tension to the pin. If you stretch the hole, it's a lost cause. There simply isn't enough meat around the hole to get carried away with a tighter fit IMHO. But...…...who knows......never have done a shrink fit before.
    I considered running a bead around the pin, but don't want to distort the bar. It's a bit of an experiment, and I suppose I'm the one that's gonna pay if it doesn't work.
    Once it's all assembled, I'm planning on rounding the edges of the bar on the outside diameter. If I do get whacked by the dam thing, I don't want it to cut down to the bone with any sharp edges. 12" is a lot of iron to be swinging around, with yours truly close to it.
    Last edited by farmersammm; 11-25-2019 at 12:56 AM. Reason: changed number, and spelling error
  18. #118
    Re: Oh, Why Not
    Name:  broken wheel96.JPG
Size:  226.5 KB Should have it together in the AM, but I thought I'd put up a pic to show the relative size of the stupid thing, and the danger it could pose in terms of getting clobbered, or having it fly off the hub. I gots some fluorescent marker paint...…...might just put a dab on the ends of this thing.
  19. #119
    Jun 2008
    New Plymouth ID
    Re: Oh, Why Not
    I did a fit a few months ago that was such a comedy of errors that i couldnt post the pictures i got a 10 lite jug of nitrogen set the shaft in that and startd heating the gear in oil. like a tight *** i didnt use new oil just some that was left over next thing i know i have steam and oil flaming 20’ in the air it had got a little water in it made it look like a roman candle. Finally got the fire out by now my nitrogen has mostly boiled off, my gear is only around 200 degrees. I went for it anyway 5” inches of the gear slid on 2” did not, thankfullyy we had machined a stop on the shaft my guy grabbed a 16 lbs sledge tapped it once and it set in place. Then i started breathing again, we must have looked like the keystone cops bouncing around.
  20. #120
    Re: Oh, Why Not
    Sounds like about how I do most things
  21. #121
    Re: Oh, Why Not
    Drum roll...……………………………………………...
    Name:  broken wheel99.jpg
Size:  124.3 KB Heated the bar up to about 800*, and it just plopped right in (whew!!) I believe it started to grab within about a few seconds. Amazing stuff MIld steel can be heated pretty high without damaging it. Makes the job a breeze with this thin stuff (1/2")
    Name:  broken wheel100.jpg
    Next up...….some stuff to align centers on the discs.
    A button that fits the bore.
    Name:  broken wheel101.jpg
    Turn it around to drill a center hole. (Gettin' real good at this 4 jaw crapola. Setup time is getting shorter)
    Name:  broken wheel102.jpg
Size:  120.9 KB The center hole is for locating the discs on the turning fixture.
    Name:  broken wheel103.jpg
  22. #122
    Re: Oh, Why Not
    Locate the fixture in the chuck.
    Name:  broken wheel104.jpg
    Name:  broken wheel105.jpg
  23. #123
    Re: Oh, Why Not
    Now, it all comes together...…..all the parts and pieces
    Center hole is used to center the workpiece on the fixture for clamping.
    Name:  broken wheel106.jpg
    Name:  broken wheel107.jpg
    Get around to turning it tomorrow, then I have a template for boring the stud holes in the hubs. Meanwhile...………. (Yeah, it's Monday)
  24. #124
    Apr 2012
    Montreal area Canada
    Re: Oh, Why Not
    Nice work! Keep your distance!
  25. #125
    Re: Oh, Why Not
    You’re fighting the good fight, I guess, but at end of the day, you’re still going to have a loader tractor with a light-duty front end and shot hubs picking up what look like bales of wet garbage. Put a front end,that will stand the gaff under a tractor and be done with it and then spend your time getting your hay made and fixing your corrals so you don’t lose cows stuck in the mud.
Page generated in 1,713,292,129.37946 seconds with 19 queries
