Results 1 to 10 of 10
Thread: Hypertherm Powermax 45 Dross
    Near San Antonio, Texas
    I get a lot of dross when I cut. I have my air adjusted correctly. any suggestions
    Mar 2005
    Under a Rock
    Re: Hypertherm Powermax 45 Dross
    Quote Originally Posted by txrpls View Post
    what size material are you cutting?
    How are your consumables?
    usually I've found excessive dross is from moving too slow.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Apr 2016
    CA
    Yes lots of dross usually moving to slow.
    I just changed them out and will see if that makes a difference. I'm cutting 1/4" thick pipe 1.5' in diameter.
    Ok, so I changed out the consumables and that made a difference. I want to cut slow as this is a weird irregular cut. How do you cut slow with this machine?
    Well, I figured it out, just cut slow and knocked of the dross with a chipping hammer.
    Apr 2008
    NW ON Canada
    Itís a combination of cut amps and travel speed. Get the combination correct and you get relatively clean cuts.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    Jun 2016
    Back to the jungle
    One setting. WFO and pull accordingly. See the spray angle ? Too slow is straight down
    Oct 2007
    New Hampshire, North Carolina
    Dross is caused by: 1. Cutting too slow, 2. Cutting with torch too high off material. If the part is detailed and you need to move slow.....turn the amperage knob down unil you are comfortable (that is what the Amp setting is there for). With experience, just like with welding processes, you will find a sweet spot that works for you. You will find that low speed dross is very easy to knock of with chisel (buy a concrete chisel at the local hardware). Finding the ideal speed by machine cutting is easy, by hand it is hard to find the sweet spot between low speed dross and high speed dross. If the height is right (correct height with shielded hand cutting parts on a Hypertherm is dragging) and the speed is right, and the retaining cap is perpendicular to the material....you will see the sparks (that exit the bottom) actually lead the torch by about 10-15 degrees when using an air plasma on steel (on stainless and aluminum the sparks should trail by 15 to 30 degrees). The manual has some good info on cutting technique.....check it out! Jim Colt
    Thanks, Jim. I finally got it figured out.
Page generated in 1,632,083,551.62457 seconds with 12 queries
