Results 1 to 23 of 23
Thread: Forklift Repair
    Forklift Repair
    Forklift be for and after repair
    The forklift hit a overpass going 55 MPH on a trailer
    The forklift only had 151 hours and a new transmission
    Need a some work after hitting overpass.
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Re: Forklift Repair
    Looks good, but I would have expected a lot more damage from an overpass. Must have barely touched it...
    Re: Forklift Repair
    It had lot of damage but most was mast
    The forklift took a big Chuck out of overpass
    The forklift is 35,000 pounds.
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Sep 2015
    SE Pa
    Re: Forklift Repair
    Any “work” photos?
    Nov 2012
    new york city
    Re: Forklift Repair
    Quote Originally Posted by Bls repair View Post
    Any “work” photos?
    i'd like to see overpass photos.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Re: Forklift Repair
    Any “work” photos?
    I use for unloading plate up to 2 1/2" 8' x 24' and loading doors
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Re: Forklift Repair
    It is North Highway 99 at Addams over pass in Fowler CA. It is first over pass out of Caterpillar Sales
    Update
    https://www.google.com/maps/@36.6340828,-119.6923904,0a,41.3y,320.56h,97.64t/data=!3m4!1e1!3m2!1s7jsAStL0JEWixzFOARh5Qw!2e0
    Puget Sound, Washington
    Re: Forklift Repair
    I’ll guess that’s a Cat V180 mid to late 70’s? 3208 and fast on the road?
    Sep 2015
    SE Pa
    Re: Forklift Repair
    Sorry, meant repair work photos
    Re: Forklift Repair
    Hard to scan those old photos. BAck in the day, we didn't take a ton of pics before digital cameras. Cost too much to develop them.
    Re: Forklift Repair
    Quote Originally Posted by Johnmm View Post
    It was V250 with a 3208 to change to V300 or V350 just and weight to box behind the engine.
    Each fork was 8" x 3 1/2”.
    The side to forklift it sink into ground and was 14' 10" tall I could not take inside a 14 foot building and I did not want put ruts in concrete.
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Re: Forklift Repair
    Quote Originally Posted by docwelder View Post
    Had one like that hit an overpass close by me, Took out the first concrete "I" beam, blew all 8 tires on the trailer and tossed the driver onto the hood of the truck. Overpass was closed for 90 days for repairs which meant an extra 15 miles when we wanted to make the short trip into town. Turned out later that I knew the driver. He's not exactly smart.
    May 2007
    Re: Forklift Repair
    Update
    https://www.google.com/maps/@36.6340...xzFOARh5Qw!2e0
    i dont get down that way much, but if i do, ill take a look at it. maybe hang one of you advertising signs over it, that way cal trans wont see it, or know who did it
    Re: Forklift Repair
    Nice fix. Your driver must have done a good job of chaining it down at least...
    Re: Forklift Repair
    I purchased after it the overpass. First owner was PG&E.
    From the roomer the truck drive was fire on the stop. The trailer was scarped.
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Nov 2014
    Netherlands
    Re: Forklift Repair
    Yeah, I worked 8 years as a pipefitter in the oilfields and at construction yards where we build offshore platforms, and although it was in the age of digital camera`s , it was before you had a camera (aka smartphone) in your pocket the entire time
    So I only have a few photo`s from that time.....
    Nov 2019
    Re: Forklift Repair
    I am a retired DOT cop and would have never guessed that forklift was 35k pounds.
    Re: Forklift Repair
    Quote Originally Posted by Dirtynails View Post
    The steering axle weight is 20,000 pounds. You add 5,000 pounds in box over the steering axle. Sitting on ground it is 14feet 8inches tall. I am know it pass all DOT spec for running down the road 😨.
    May 2007
    Re: Forklift Repair
    [QUOTE=smithdoor;8729082] Sitting on ground it is 14feet 8inches tall. I am know it pass all DOT spec for running down the road ��.
    Dave[/QUOTE
    i have hard time thinking pg&e would take it on a trailer down road w/o laying mass down. pg&e would ratherr there drivers drive all the way around the block, rather than back a trailer into an area, if it can be driven in. also, there policy is, if two guys in cab, one must get out to back/motion the driver to back in no matter how short/open distance.
    Re: Forklift Repair
    It was a trucking company not pge.
    The overpass is 16 feet.
    The driver did a opp's .
    You can tilt the mast forward on 18" trailer down to 13-6.
    On trailer the driver did not tilt the mast and left it up too.
    Want can go wrong will go wrong.
    [QUOTE=123weld;8729086]
    Dave[/QUOTE
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Re: Forklift Repair
    It was not a PG&E truck
    I do not why it was a private trucking company.
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Dec 2011
    Re: Forklift Repair
    I have a friend with one like that. He had to move it and when he let the mast down he used a come-a-long to control it when he let it down. The cable ran out of the come-a-long and came loose and just about broke the mast off the frame/differential. Lots of weight and very hard to move on city/interstate roads. He should not ever have to move it again.
    Re: Forklift Repair
    Quote Originally Posted by mwshaw View Post
    It not hard to remove mast .
    1) remove hydraulic line on mast cylinder.
    2) remove pin in tilt cylinder
    3) There two plate at bottom that remove.
    4) just lift off other forklift.
    I put on only on the mast it took a 1/2 hour. I was returning the other 8,000 pound forklift be for lunch.
Page generated in 1,713,261,556.63663 seconds with 19 queries
