Results 1 to 4 of 4
Thread: Thermal arc 181 gas solenoid
    Seems like the solenoid valve is sticking as it takes about 8-10 seconds for gas to stop flowing. I checked voltage to valve and it seems to be correct with the trigger altho when using the test meter it displays 24 volts DC for a short time after I release trigger. It also takes a short amount of time to register voltage after switching the trigger. Anyway I haven't been able to find the exact valve but have found some that are 24vdc with 1/4" npt which I'm sure I can adapt with Barb fittings. Plenty of room inside for it. Any concerns with pressure or compatibility with argon?Name:  15741264477131128345033049146730.jpg
Size:  185.4 KBName:  15741264477131128345033049146730.jpg
    Re: Thermal arc 181 gas solenoid
    I don't know how I got 3 pictures of the same thing.
    Jun 2011
    Aiken SC area
    If it fits, go with it as long as it's the same voltage as the original. Bob
    George,( mechanic 416) told me how to disassemble and clean solenoid valve and all works good now.
Page generated in 1,624,073,646.44915 seconds with 14 queries
