Results 1 to 25 of 45
Thread: Turntable on Rollers With Track
    I grabbed this turntable and three sections of track from a sandblast shop this morning.
    The turntable is 1/4” x 30” diameter with 1/2” holes for bolting fixtures. Sealed bearings on turntable and the four rollers.
    It has a rated capacity of 750 pounds and weighs 90 pounds.
    The turntable unit itself sits flat on the floor or welding table (rollers do not engage the flat surface) and as such can be used for rotation only without the benefit of linear travel.
    Lots of options available to me. I think I will make a dedicated bench for it that will allow me to clip on track extensions. This still allows me to grab the turntable and use elsewhere at variable heights with a forklift or high lift pallet jack.
    Too cool or what??!!
    Re: Turntable on Rollers With Track
    Pretty cool. It could actually go under /hold a small table too. Are those rods for the extensions? How do the line up?
    The rods must have been for alignment for the bench they had in their blast booths. I will need to make my own latching and alignment setup.
    Sep 2015
    SE Pa
    What do you use for a stop?
    Quote Originally Posted by Bls repair View Post
    Nothing at the moment as I just acquired the pieces.
    When I figure how and where I want to set it up I can weld a tab on the track assembly to limit linear travel. I don’t think I’ll need a mechanical brake on the turntable but I’ll wait and see.
    Pretty neat.
    You could sit a chair on it, sit yerself down in that chair, and have someone spin it till ya throw up Kinda like astronaut training
    Very cool!!!!! Man I can think of several projects I did where that would have saved a lot of time and me jumping back and forth...
    Ah man, that is slick. For a temp stop, use a C clamp, beam clamp, drill hole for bolt and nut. You know what to do, just being smart a$$.
    That could really be handy. I'm glad I didn't find it.
    That's slick using angle iron for track too.
    I'll settle for my overhead beam with electric chainfall . Probably one of my best investments, especially now that I'm getting old.
    Putting eight feet of track on my bench and motorizing the turntable was what first came to mind.......
    Jun 2017
    AJO, ARIZONA
    Wow nice piece! Your shop looks too clean to be used, I can't seem to keep mine clean if I'm doing anything.
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    JEFF
    I spent a little time working on a bench for the turntable today.
    The main frame on the left will be moved with the pallet jack. The 3 foot tracked extension on the right will be detachable and have a (lift off) flat work surface adjacent to the rolling turntable.
    The 30 x36 inch lift off flat surface may have to be thick MDF or aluminum as a steel top may be too heavy. Haven’t figured that out yet....
    I’m getting closer. Still need to make a removable tabletop.
    Feb 2012
    Jacksonville, FL
    A track like that would work great for loading wood in a shipping container kiln for drying wood.
    Southern California
    That is an awesome find. Great idea for quick track alignment too.
    I can't think of any specific ways it would have saved me time or hassle over just a rotary table but I definitely want 3, maybe 4 lol.
    I like that industrial look of the holes punched in the channel/ibeam. Little touches like that can make something as utilitarian as a workbench look really nice. Your shop is always enviable and clean lis2323.
    I was unable to find an aluminum sheet crop cheap enough so I used a piece of 1.25 inch plywood from a Starbucks coffee table and sheared up a piece of 18 gauge galvanized I had. Not my first choice but I think it will be fine for now.
    Close up of intermediate shelf
    and clamp hanger
    Thanks, SlowBlues!
    Apr 2014
    MN/WI
    You get your materials from Starbucks ???? How do you get a table out the door and loaded into your truck before the Baristas catch you?
    Lincoln Idealarc TIG-300
    Quote Originally Posted by bead-boy View Post
    LOL... looks great... I might have to attempt a really ugly, dirty version of it some day.
    Jan 2008
    PNW/Kodiak
    Excellent score; and your shop is immaculate.
    I do find it odd how this picture was seemingly glossed over by other members... Stainless?? Sanitary grade? Or is my mind in the gutter?
    Do you really know all of the work that goes into getting that fish onto your plate?
    Thank you, jeverich. Stainless, btw.
    I chopped the end off some sliding arm clamps today
    and welded on 1/2 inch bolts to match the holes on the rotating table.
    Mar 2017
    Dubai
    Very nice as usual. Aren't these clamps hardened enough for you not to use the Makita LC1230 on them?
    Quote Originally Posted by precivilization View Post
    That’s a good point. I didn’t even consider...
    I should have used the abrasive chop saw or a cut off wheel.
    Quote Originally Posted by jeverich View Post
    Those of us that have drooled over Terry's shop pics for years have learned to mask our deep rooted feelings of envy and inadequacy by silently staring dumbfoundedly from the corner....
  26. Likes akpolaris liked this post
Page generated in 1,713,254,547.18737 seconds with 19 queries
