Results 1 to 9 of 9
Thread: Pipe line work just a great day
    Just great day
    https://www.bing.com/images/search?v...2,4,6,8&sim=11
    Why a great day He walk away
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Jul 2018
    Beavercreek, Ohio
    Re: Pipe line work just a great day
    wow....lucky guy
    Gregg
    Hobart Handler 210 MVP
    Hobart Stickmate 210i
    Saw a guy get a broken jaw cutting 6" pipe, he pulled it up out of the trench with the crane on his truck and obviously didn't think it out.
    I had to take a section out of a 24" line to install a gate valve on top of a hill once, expecting the same result we cribbed the pipe and held it down with 2 large excavators. We still had some movement, not much and the beveling rig rode it out just fine.
    Nov 2012
    new york city
    lesson learned the hard way.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Sep 2015
    SE Pa
    Bet he isn’t constipated anymore
    Apr 2016
    CA
    How does one cut a pipe like that safely with out having to worry about the built up spring in the pipe?
    Oct 2019
    Australia
    Big pipe like that can build up big forces as seen. The excavators was a good idea. You could also weld some serious threaded dogs over already cut sections to hold it with bolts and when fully cut wind the bolts out.
    Nov 2012
    new york city
    have the helper cut it
    i.u.o.e. # 15
    Quote Originally Posted by docwelder View Post
    Actually on large bore pipe the best way is with a cutting rig, I have an H&M rig that crawls a band clamped to the pipe. It has a 15 foot flexible shaft with a crank to drive it (yeah, I'm cheap) but it's better than being on the pipe doing cutouts. I really like it for doing cuts on vertical pipe like well casing, have bands from 16" to 30".
Page generated in 1,623,730,231.91297 seconds with 11 queries
