Results 1 to 14 of 14
Thread: Helium tank
    Jun 2017
    AJO, ARIZONA
    Helium tank
    I have an opportunity to buy an aluminum helium tank, I think it's about a 125 cubic foot bottle, they want $50.00 for it with a balloon attachment. Does anyone know if it could be filled with CO2 as I have no use for the helium, I think the price is very good, don't know if it has any gas in it or not. What do y'all think?
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    GOD HELP AMERICA!
    ďFreedom is never more than one generation away from extinction.
    We didnít pass it to our children in the bloodstream".
    RONALD REAGAN
    Re: Helium tank
    As far as I know helium uses a valve similar to argon , so co2 would be different.
    Jun 2017
    AJO, ARIZONA
    Re: Helium tank
    I was thinking more along the lines, hoping my supplier would swap, they have offered to do this with one of my C25 bottles, exchanging for straight Argon and paying for the gas, completely fair IMO.
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    GOD HELP AMERICA!
    RONALD REAGAN
    Re: Helium tank
    I would check to if been tested in last 5 years. If great it my have fail the last test.
    If you fill with CO2 you can no longer fill with other gas.
    I do not know why.
    You will need to have a value for C02.
    Northern Cal., Shasta County
    Re: Helium tank
    What are the typical helium tank pressures?
    May 2010
    Port Orchard, WA.
    Re: Helium tank
    Helium comes in handy when Tig welding thick aluminum. Pretty much cut the AMPS in half from using 100 % argon.
    Donít pay any attention to me
    Iím just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Sep 2008
    Dalton, GA
    Re: Helium tank
    Ask your gas supplier about exchanging for CO2. My dealer will exchange bottles of same size for different gas.
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 120
    10FtDrillBit.com
    Jun 2017
    AJO, ARIZONA
    Re: Helium tank
    I guess that would be great "IF" I had an AC machine for doing aluminum, or will helium allow aluminum on DC.
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    GOD HELP AMERICA!
    RONALD REAGAN
    May 2010
    Port Orchard, WA.
    Re: Helium tank
    Yes you can use DCEN with 90 % plus helium.
    https://www.esabna.com/us/en/educati...g-aluminum.cfm
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Jun 2017
    AJO, ARIZONA
    Re: Helium tank
    Thanks Carl
    I have never messed with tig at all, and done limited amount of aluminum with mig and even less with the stick electrodes, I guess for $50.00 I'll grab the tank & play around some.
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    GOD HELP AMERICA!
    RONALD REAGAN
    Aug 2009
    Re: Helium tank
    For 50 I'd do a visual and if it looks good grab it on principle. (IMO you can never have too many cylinders. I never run out of gas because since cylinders don't depreciate I snag all the deals I can.)
    If it looks like this https://gascylindersource.com/shop/i...lium-cylinder/ then it's similar to the common CO2 cylinders and they may swap for one of those but CO2 has a different CGA-320 valve. You may also be able to swap for MIG mix or anything that comes with a CGA-580 cylinder valve.
    Jun 2017
    AJO, ARIZONA
    Re: Helium tank
    Quote Originally Posted by farmall View Post
    My thoughts too. If I can't use it as is I'll swap it for an argon cylinder and carry on.
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    GOD HELP AMERICA!
    RONALD REAGAN
    May 2010
    Sparks, NV
    Helium tank
    Balloon helium generally has a percentage of oxygen added to it for folks that suck on the helium for the old Mickey Mouse effect dont suffocate themselves. So itís not usable for welding.
    Long Island
    Re: Helium tank
    While that is true for parade floats, it is not true for compressed helium cylinders nor the party tanks you can get in many stores. Those, and normal helium balloons all use pure helium only. Mixing oxygen into compressed gas cylinders that are prepared for inert gasses can be very dangerous.
Page generated in 1,623,660,512.59444 seconds with 12 queries
