Results 1 to 12 of 12
Thread: Dayton 295amp AC buzz box HELP!
    Dec 2019
    Hi all, new to the forum. Just got a really good Christmas deal off of Facebook.
    Picked up a Dayton 295 amp ac arc welder with the hi/low plugs on the left side. It has the lever arm you move to adjust it and a locking mechanism that holds it. Guy gave me a ton of rods to go with it. 6011, 6013, 7018 etc etc. Got the cables and all of this for free. So I brought it home and today I took it out to the shop to test it out.
    I have it plugged to a 220v. When I flip the switch nothing happens, fan doesn come on and I can't strike an arc. I blew everything out with my air compressor. Checked the wiring and everything is snug. Checked continuity along power chord and good. Jus not sure where to go from here. Any help would be appreciated, I fix and ride alot of sleds and bikes and I'm mechanically inclined. Happy New year's btw!
    ct.
    Re: Dayton 295amp AC buzz box HELP!
    Do you know that you have 220v at the receptacle and
    that the receptacle is wired correctly ?
    Have you checked for continuity across the two blades of the
    welder’s plug with the power switch in the on position?
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Dec 2019
    Power is at the recepticle and it's wired up right. I can check for continuity across the live blades when I get to my shop.
    Dec 2019
    I know these welders were all made by century if I correct. If anyone has a manual they wouldn mind sharing I'd be mighty appreciative.
    Dec 2019
    Jan 2016
    northeast USA
    open it up and see if you get 220 on both sides of the switch when turned on..there may be a reason it was free.....could be a broken or burned wire, or some critter got inside and started chewing away...
    Dec 2019
    Checked continuity on live prongs and i have continuity. Checked with it off and no continuity so switch is good.
    Dec 2019
    Had it opened up last night when I blew it out, everything is connected up good, no chewing or anything just alot of spiders.
    Question do these make any noise when they turn on? Or do they only make noise when you strike an arc?
    And should my fan kick on when the switch is turned on?
    Jan 2016
    northeast USA
    Quote Originally Posted by Vintage View Post
    depends if the fan is on a thermostat or kicks on all the time...you should hear some sort of humming when turned on, not loud but some low level humming.... are you sure the switch is working??? check with a volt meter to make sure the 220 is going through the switch..
    heres a parts break down for it..
    https://weldingweb.com/attachment.ph...6&d=1287381788
    ct.
    My buzz box and every other one I’ve used makes a fairly loud
    buzzing sound when turned on. Also fans run continuously on
    all transformer type that I’ve seen. With power at the receptacle
    and continuity across plug, seems like either fan would run or
    transformer would hum.Do you have a multimeter?
    My next step would be to check for power at the switch.
    Or measure resistance across plug with switch on.
    (Should be very low, probably less than 10Ω)
    Millermatic 180
    Purox O/A
    Dec 2019
    So resistance across the plug was around 18-20 ohms with switch on. No reading with plug off. It's got a dryer style 3 prong spliced onto the original chord it looks. I took I apart, rejoined all he connections along with Makin sure ground was wired up right. No him or fan kicking on. Figured the resistance might be high because of the spliced chord if anything. When I had it apart I checked all the connections and they looked good. I know that these units are very unlikely to go bad.
    Does anyone have one of these that wouldn mind getting me some readings with a multimeter? This way I can go through and check components 1 by 1?
    ct.
    Have you checked for voltage at switch ?(as Hobbytime suggested).
    I would suspect plug ,cord or wiring of them.
    Millermatic 180
    Purox O/A
Page generated in 1,665,103,637.22955 seconds with 14 queries
