Results 1 to 7 of 7
Thread: Trailblazer 250G remote 14 question
    Apr 2018
    Wooster, Ohio
    Hello
    I have an early 90's TB 250G. I bought a Spoolmatic 30A to run off of it, along with a WC-24 to connect it to the machine. When I plug in the WC-24 to the machine it immediately goes to weld/ power speed. I'm just wondering if that is normal or if there is a wiring issue in the WC-24?
    The Spoolmatic works great! I was thinking the engine would idle until I pull the trigger on the gun. Thanks in advance for any help.
    Re: Trailblazer 250G remote 14 question
    Hello,if you have the WC-24 box plugged into the 115v jack for power it will idle up your trailblazer just like when you run a grinder .
    Miller aead 200le
    Miller bluestar 2e
    Miller Dial Arc hf-p
    Miller cool mate 1
    Millermatic 35
    Lincoln weldanpower ac/dc -cc/cv
    Lincoln 140hd
    Porter cable metal chop saw
    Hypertherm Max43
    Miller Trailblazer 250G
    Apr 2018
    Wooster, Ohio
    The WC-24 only plugs into the remote 14 receptacle.
    Yup ment to say 14pin amphenol were it does also get the 115v
    Miller aead 200le
    Miller bluestar 2e
    Miller cool mate 1
    Millermatic 35
    Lincoln 140hd
    Hypertherm Max43
    Apr 2018
    Wooster, Ohio
    Okay. Thanks much!
    WC 24 runs on 24 vac. and yes there is 115 and 24 vac at the 14 pin plug.
    The 115 volts is being removed in a lot of new machines.
    And yes it is working right. when current is being used in the 24 and 115 volt supplies, the welder speeds up.
    Apr 2018
    Wooster, Ohio
    Thanks to both of you for the info. I really appreciate it!
Page generated in 1,638,793,375.53370 seconds with 13 queries
