Results 1 to 25 of 29
Thread: 110dc power to 110ac power
    Mar 2019
    north of 49 parralel
    Hi guys Iíve got a Lincoln sa200 blackface which puts out 110dc aux power does anyone have any ideas how that can be changed to 110ac for powering varies pieces of electrical equipment which are not dc compatable ; any info would be appreciated
    Re: 110dc power to 110ac power
    I think about the best you can do is put a large output alternator on the engine, use a good sized battery and run a power invertor. I've had several of those machines and the lack of AC power is part of the reason I moved on to Miller Trailblazers.
    Mount Tabor VT
    I have an inverter for my truck. It makes 120 AC from 12 DC. What is available able to work from fluctuating voltage, I don't know. I assume you towed this welder to the job.
    You can get inverters for higher DC voltages also 24,48,96,120,+++ but they'll cost more than $49.95
    Mar 2019
    Thanks guys for your reply's , is the inverter the only way to go & would they power a 7" grinder that requires 15 amps , I've been told by various people that dc power will burn out grinder switches & do all kinds of damage to other power tools ,drills lights cordless chargers etc ! So this is why I'm trying to come up with a different plan for proper power! Btw does anyone on the web know how to identify the age of Canadian made sa 200 generators as they don't have code numbers or any letters or numbers stamped on the barrel , I have 4 sa200 machines 3 hex barrels engines dated 1973 -1974 1 round barrel 1942 stamped on engine ,& 1 round barrel generator only no numbers anywhere?
    You should probably should shoot for powering a good 4 1/2" if going inverter.
    Most 7" draw between 11 and 15 amps. I have a high quality inverter that is only good for bit over 10 amps AC and it draws 127 amps of DC.
    You would need some big batteries and pretty good charging system to not succumb to the load. If it was limited use and run time in between was a bit.
    Thinking a small generator may almost be as useful and cost about the same all said and done. Inverters eat DC battery power for sure.
    Sebeka and Bemidji MN
    SA-200's been powering grinders for decades.
    Just look on the grinder tag, it'll say if it's AC/DC.
    Drills, or anything else with a variable speed switch, are generally not. But again, look at the tag.
    For small AC power, an inverter off your battery like said above - or Honda 2000 watt.
    Here is just one example: https://www.homedepot.com/p/Milwauke...-31A/203405174
    Syncro 350
    You need to look for power tools rate for 120 DC.
    I even a rod heater on 120 DC
    The old welder generator only 120 DC.
    If want 120 AC just add a belt drive generator.
    Quote Originally Posted by little charlie View Post
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Mount Tabor VT
    I don't see new tools rated for DC, but 50 years ago most all hand tools would run DC as well as AC. Not sure that will work these days.
    You can still get AC/DC stuff.
    https://www.ebay.com/c/25024432294
    https://www.milwaukeetool.com/Produc...nders/6121-31A
    https://milwaukeetool.com/Products/P...d-Saws/6238-20
    Jun 2017
    AJO, ARIZONA
    I think that option went out the window with electronic switches & speed control, I think any of the older drills & grinders will pretty much work, anyway that's what I was told by an old timer Locomotive Electrician. A 120v drill worked great on the 74 v dc in the Locos.
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    GOD HELP AMERICA!
    ďFreedom is never more than one generation away from extinction.
    We didnít pass it to our children in the bloodstream".
    RONALD REAGAN
    May 2015
    If you're looking to run something like 15 A at 120 V Your Cheapest option would probably be a 2000 W or bigger generator. Good quality inverters that are capable of 2000 W or more get expensive pretty quickly not to mention you'll need a bunch of other odds and ends to make that solution work.
    Mount Tabor VT
    My inverter for my van cost $275 it is 6000 watt continuous, but you won't do that long powered by a 200 watt truck alternator. I haven't had occasion to grind all day, or even run a cut off saw long term.
    One of my service trucks had a 3000 watt inverter powered from a group 4D battery that also powered the crane, it was set up to charge when the truck was running through a constant duty relay solenoid. I was installing a drop axle on a dump truck and we ran off the inverter all day running the big Milwaukee drill and using 5" and 9" grinders doing cutoff work plus a lot of crane time. All that and the low volts alarm never came on. The truck had a 140 amp alternator and the battery stayed charged when you drove it, plus I had a 10 amp onboard charger that was plugged in every night.
    Mar 2019
    Ok well thanks to all you guys for your valuable info & input, I guess my first thing to do is check if all the tools I would use are ac/dc or not / I’m not into replacing them if not so I will have to look at my options the belt drive generator seems to be a good option but I was thinking of running a belt drive compressor on the unit so I guess that would rule out 1 of the options will have to mull this over and see what the end result will be . My motto is there’s no such thing as you can’t lol
    You never did say how much you had/wanted to spend to make it happen... $15... might take a lot of redneckin' 15 grand and no problemo you'll be up and running as soon as brown brings the box!!!
    There are a lot of ways to skin this cat depending on the 'level' of work you want to put into it and the $$$$ of course and also just how good/authentic you want the power to be.... ie.... 170 p-p(120acv)pure sine or chopped 120 cd with a -60 bias or maybe some inbetween modified wave type of AC...
    Mar 2019
    Thanks for the input ronsii just need enough power to run the tools you would need for a regular days work repairing heavy equipment without burning any of it out, not looking for anything for $15 or $1500 just something in between
    Do you have your SA200 on a service truck? You might try the inverter/big battery trick. Worked for me.
    Mount Tabor VT
    Belt drive gets fussy as there is no voltage regulator tied to your throttle. You won't have exactly 60 Hz, or 120 volts. Might be better with a generator from Harbor freight.
    Dec 2016
    Running my 7in grinder at work and I checked. It will run on 110dc
    Dec 2016
    Mar 2019
    Thanks willieb & ljmelius wouldn't e belt drive generator run at the proper rpm give you the proper 110 -115-or 120 volts ,interesting to see some of the grinders have ac & dc stamped on them , my makitas don't seem to have it stamped on them but the specs say that a 5" is ac dc will have to check on the rest of my tools asap ,
    Dec 2016
    Deleted
    Mount Tabor VT
    The simplest AC generators only regulate speed to control frequency. A two pole generator has to turn 3600 RPM. A 4 pole needs 1800 RPM. This provides 60 HZ. If you have no governor linked to frequency, you won't have 60 HZ & might not have 120 volts. More sophisticated generators control both engine speed & field strength to regulate voltage.
    There are inverter generators producing any which power, they then electronically convert to 120V 60 cycle.
    Mar 2019
    Thanks willie b I will have to look into this further I’ve got a buddy that knows more about electrical & generators than i do but he,s not around at the moment, will pick his brain when he gets back,
Page generated in 1,623,727,169.46933 seconds with 11 queries
