Results 1 to 11 of 11
Thread: Transformer repair
Hybrid View
    May 2018
    Transformer repair
    Iíve got a miller thunderbolt that needs the transformer lead spliced . Thought Iíd ask someone who maybe had a better idea and the best way to splice it together again. Thanx !!!
    Jan 2016
    northeast USA
    Re: Transformer repair
    post some pictures of what you have to work with..
    Quote Originally Posted by hungrybare View Post
    Most modern welds today have aluminum. I would use splice in copper wire. Using Split Bolt Connector for Copper and aluminum and Anti-Oxidant Compound.
    I have found this works best for high amperage.
    https://www.lowes.com/pd/Gardner-Ben...mpound/4514334
    https://www.lightingsupply.com/penn-...20group%20%231
    May 2018
    Thanx Dave, Appreciate your reply. Should be a pretty easy fix
    Jan 2016
    northeast USA
    take some fine emery and clean up about an inch on both sides of the crack, if its copper I would braze it back and be done, if its copper coated aluminum I would find a mechanical means to fasten them back together..
    May 2018
    Thanx hobbytime , ya itís aluminum taking it out to get at it better my all thumbs hand slipped and broke the fan blade. JB weld back together, If that doesnít hold I guess a new one is only about 15 dollars.
    Jan 2016
    northeast USA
    Thanx hobbytime , ya it’s aluminum taking it out to get at it better my all thumbs hand slipped and broke the fan blade. JB weld back together, If that doesn’t hold I guess a new one is only about 15 dollars.
    you can use a wire splice like this...to connect both sides of the break..fan blade should be cheaper than that...just look for one on amazon and make sure you get the proper rotation one..
    https://www.amazon.com/Morris-90615-...%2C166&sr=8-32
    Your welcome
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
  9. Likes fixit32068 liked this post
  10. #9
    I put that through an online translator:
    I have no idea, but at least now I can honestly say I have no idea. Lol.
  11. Likes MinnesotaDave, CAVEMANN liked this post
Page generated in 1,627,387,642.47834 seconds with 13 queries
