Results 1 to 18 of 18
Thread: Magnetic work lead attacher DIY
    Pensacola , Fla
    For those that may want to make a magnetic work lead attacher here is one a guy made DIY type
    https://www.instructables.com/id/Mag...m_medium=email
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
    Re: Magnetic work lead attacher DIY
    I picked up a larger magnet at Princess Auto for $5 Cdn. .... pretty sure you guys south of the 49th could do better at Harbor Freight. I drilled a hole in the back of the welding clamp for it so I can use either side. Have to admit it's picked up it's share of the grinding chips though... Good idea for DIY, I'm just not sure the work is worth the effort of saving $5.
    Cut 50 Plasma
    I’m all for DIY but aren’t similar ones available for “like not much at all??”
    I like switchable ones as I don’t want to have a magnet drag my “masterpieces” out of position during setup for tacking.
    Plus the swarf it attracts like whtbaron mentioned.
    Mar 2005
    Under a Rock
    Also the switchable ones make brushing off the steel shavings and any boogers very easy.
    but they suck for aluminum....
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Delaware
    Also remember to let them cool and wear gloves when you remove them. Burnt the He!! out of my hand ones, never used it again after that.
    [QUOTE=Lis2323;8738264]I’m all for DIY but aren’t similar ones available for “like not much at all??”
    Plus the swarf it attracts like whtbaron mentioned. ] "
    Cool... never seen the switched version before... I know there's been times when I have removed mine from the back of the welding clamp because it was being a pain and attaching to things I didn't want it to. The switch would be very handy.
    Cut 50 Plasma
    Also the dust impact surface contact. Causing arc and poor grounding. In the field, I used to use one like lis2323 posted. It got hot and weaker. The aluminum base got a lot of Arc marks on it. Never could keep it clean, even switched off the stayed in the recesses.
    A swipe with a wire brush helps clean weld magnets it much work for the non switching grounds??
    I agree. I’m sure I don’t do anywhere near the amount of welding you do and mine is showing the same symptoms. Not certain if the higher amp rating unit would have a longer user life or not.
    I found that using a stainless wire brush works great on the basic welding magnets.
    Magswitch are my favorite. The last couple of years, their best sale has been around Christmas. Sign up for their emails and watch for clearance sales.
    My favorite ground clamp is a small one like on a 12 volt car battery charger. I use this exclusively for my artwork. You can use the clamp to hold the piece you are tacking . It makes a difference having a positive ground connection.
    I recall you got a few really good deals Bob.
    Nothing I want from Magtools ever comes on sale. Plus their free shipping in continental US doesn’t do me any good either. It ends up cheaper buying from Amazon
    Yes sir, myself and many here bought the Magswitch RIDGID boomer angles. They were crazy cheap on sale and had free shipping. I'm set on Magswitch goodies but wouldn't mind getting their pivot angle.
    https://magswitch.com/product/pivot-angle-200/
    Mar 2017
    Qatar
    I love magswitch products, but I think This may do the same job and for much more less
    https://fireballtool.com/magic-square/
    Miller Dynasty 280 DX TIGRunner
    Fronius Transsteel 2200
    Quote Originally Posted by precivilization View Post
    Thanks ,I have seen that before.
    I might just may fab my own. I have four of those boomer angles so I could remove two magnets from one of them.
    Arizona
    hmmm... I just bought a harbor freight magnet, plopped it onto the work piece/table and put my work lead clamp on the bolt it came with. It is a bugger to remove from the table though, have to slide it over to the edge.
    Miller Challenger 172
    Miller Maxstar 150 STL
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Smith O/A little torch
    No, that's not my car.
    Fredericksburg, VA
    I have one of those Magic Squares. I was using it today to hold a piece of aluminum at an odd angle.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
    Mar 2017
    Qatar
    Is it as good as it seemed on the video?
    Fredericksburg, VA
    Yes. Being able to set any angle, take them apart for two squares, using them standing up on end as a tall support, etc. I have used them for all that.
    Millermatic 252 MIG
    Fredericksburg, VA
    I bought a set of the 8 inch cast iron mega square and 8 inch monster squares last year at fabtech. I also bought one of the magic squares at that time. These are for personal use.
    Later I had my work buy the same items plus the shim kit.
    This year at Fabtech I bought a set of the minion squares for personal use.
    I like that the mjnion squares are nitride coated. I wish the other items I bought were coated to help prevent rust.
    Millermatic 252 MIG
Page generated in 1,624,028,735.84698 seconds with 12 queries
