Results 1 to 11 of 11
Thread: Century Monkey be Wards AC DC repair
    Apr 2020
    VA
    I need to make it work. It is completely dead.
    Has power in past the switch, but nothing out. No humming, no fan.
    Big Lake/Monticello MN
    Re: Century Monkey be Wards AC DC repair
    What did it do when it died?
    Died while welding or worked one day, dead the next?
    Syncro 350
    Apr 2020
    VA
    I bought it as working, it's not.
    Arizona
    Did you check to make sure you have 240? What instrument are you using to determine voltage? Sounds like maybe you only have 120. Check leg to leg at the outlet and again inside the machine. If you have 120 between hot and ground but zero between hot and hot you are hooked up wrong.
    Miller Challenger 172
    Miller Maxstar 150 STL
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Smith O/A little torch
    No, that's not my car.
    That's where I would start too.
    Syncro 350
    Apr 2020
    VA
    120 on each hot wire.
    I'll double check the ground.
    Don't think that's it though.
    Checked with a multi meter.
    Apr 2020
    VA
    Finally some good news.
    Turns out my outdated circuit breaker box doesn't connect to the two busbars at every two stations. I had to take it loose and wiggle the busbars to figure out that of the six stations, only the inner for would work for 220. Welder makes that happy humming noise now.
    Arizona
    Quote Originally Posted by Nessmuk View Post
    What about from hot to hot?
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Arizona
    Sounds like you have a GE or a Federal Pacific. Which is what I was getting at with my questions
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Apr 2020
    VA
    I appreciate all your help. It's just good to get it going.
    Jun 2008
    Central California
    I know this is an old thread and the problem was actually in the supply line, but... a welder like this has simple wiring inside; plain wiring between the transformer and the connectors on the front panel, a rectifier in the DC circuit, but no solid state circuitry. Just a moveable core for current adjustment. Should have been easy to visually inspect, or to check resistance of the wiring in the main transformer to find any problems.
    FWIW, I probably still have a Wards catalog, or a page from one, listing this unit. Maybe from the 1980's?
Page generated in 1,713,305,132.03739 seconds with 19 queries
