Results 1 to 25 of 42
Thread: Cake stand
    Jul 2018
    Cumbria, UK
    Cake stand
    For our wedding in July (if the 'Rona allows it)
    I've been keeping quiet about this, mainly because I was scared that it might turn out horribly. Now that I've got this far, I THINK it will turn out fine
    I wanted to make my own wedding cake stand! To be different, and experiment a bit. So Copper it was. I also wanted a circular twist of some sort to it.
    I started by experimenting with the TIG, with bits of copper brake tube, sheet offcuts, with electrical wire as filler, also tried silicon bronze but I wasn't confident of making a nice job with it.
    I liked this - autogenous pulsed TIG. I went with this for the bases.
    Marked out
    In process
    Bases done
    Set the centres using a plum bob, and some "custom" spacing... oh well, at least it's level
    Fitting up the side struts
    The tubing and the sheet are quite different. The sheet is pure deoxidised copper, and after welding it's annealed so soft that it's almost like lead. It work hardens very fast, though, and it doesn't have to do very much work anyways. The tubing I THINK will be arsenical copper, for pressure rated strength, it's thinner, welds just fine, and doesn't barely anneal at all. Which is good - needs to have some strength about it. It's almost impossible to seal the tubing up, as it takes a bunch of amps to melt it and heats the whole thing up so fast, the escaping gas blows a huge hole. So I've left it unwelded on the insides.
  2. Likes wb4rt liked this post
  3. #2
    Jul 2018
    Cumbria, UK
    Re: Cake stand
    Sides tacked
    That's as far as I've got with it. I'll weld them out tonight. It's been a bit of a slow project, because copper is expensive, and I really want it to look good and "as welded" so quite nerve racking to get the fits just right.
    I MIGHT have to add a third strut to one side, depending on how stiff the two struts are on their own once I take the spacing out. ATM those two are equal and opposite so when done it will leave one side open for the cakes.
    Obviously once I've finished the making, it will get a deep polish and let that lovely copper shine.
  4. Likes LtBadd liked this post
  5. #3
    Mar 2004
    hueytown, ala
    Re: Cake stand
    Hi Munkul, I like your design and creativity. One idea I'll add.. as a husband of a professional cake decorator with 25 years of professional cake carrying... I've carried thousands of cakes for miles ( the caterers and flower people take the good close parking places !!) It's hard to judge size from the pictures, and Extra rich homemade wedding cakes can get heavy. Consider the weight that all three layers will add to the stand. Do a few tests to make sure your design will support what it needs.
    The only thing worse than a leaning wedding cake is dealing with the mother of the bride with a leaning wedding cake...and another thing, let the decorator see the stand before she does the cake. as the tubes turn up to the next layer they cut down on the available diameter of the layer.. i.e. a 16" bottom going up to a 14" middle. Up toward the 14" plate you don't have a full 16" for the bottom cake..Lots of brides and decorators like tall layers... decorators size their cakes based on the number of servings they get from them. just some thoughts. And that piece polished is gonna be beautiful. Be sure and post some finish pics with and without the cake,
    john
  6. Likes Mikel_24 liked this post
  7. #4
    Apr 2014
    Re: Cake stand
    Well, this is a first for WW. Your cake stand goes well beyond being just "fine". Amazing design... so simple yet elegant. It is really going to make a statement at your wedding. There's no chance of your bride to be not loving it the moment she sets eyes on it so put all those thoughts out of your mind. It's beautiful.
    You just fabricated a piece that your children will use at their weddings. Something that can be passed down generation to generation.
    MM 211
    Smith Tru Lite O/A set, Thanks Bob!
    Lincoln AC-225
    But you must not change one thing, one pebble, one grain of sand, until you know what good and evil will follow on that act. The world is in balance, in Equilibrium- Ursula K. Le Guin
  8. Likes Munkul liked this post
  9. #5
    Jul 2018
    Cumbria, UK
    Re: Cake stand
    thanks John, your comments are very much appreciated.
    You're absolutely on the money about the diameter of the spirals. In fact, just after I posted the thread this morning, it hit me! It's not a huge cake set - 12", 9" and 6" - but I will have to alter it if there isn't enough clearance. I'm glad I hadn't welded out the joints yet!
    I probably will end up putting a 3rd spar in there for strength, because the design doesn't lend itself any strength.
    Now i might end up cutting those spars off and making new, wider ones.
  10. #6
    Oct 2013
    Long Island, NY
    Re: Cake stand
    mmm monster zero.
    www.FirehouseFabricators.com
    Zach
    Lincoln 210mp
    Lincoln SW200
    Hypertherm Powermax 45xp
    2x4 CNC Plasma Table.
  11. #7
    Jul 2014
    Re: Cake stand
    That is going to look spectacular once polished. It looks fabulous as is. Very impressive..
    Sent from my LG-H700 using Tapatalk
  12. #8
    Colorado Springs
    Re: Cake stand
    Very nice stand, and congrats on the nuptials.
    Sent from my XT1635-01 using Tapatalk
    Lincoln 175
    Monkey Wards 230v. Stick
  13. #9
    Wenatchee Washington
    Re: Cake stand
    Looking good! Plus, you can use that for a condenser for your copper still when the wedding over... Just sayin.....
    Lincoln Precision TIG 185.
    Flex-Loc 150 torch.
    Super-Flex hose.
    Lincoln MIG 180.
    Victor Oxy/Act torch set.
    DeWalt Bandsaw with SWAG stand
  14. #10
    Re: Cake stand
    Just too flippin’ AWESOME, Munkul!!
    Can’t wait to see it polished up.
  15. #11
    Oct 2013
    Ohio
    Re: Cake stand
    Make sure to take it with you after the divorce......
  16. Likes Mikel_24 liked this post
  17. #12
    Feb 2016
    Myrtle Beach
    Re: Cake stand
    Very Nice! Congratulations!
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  18. #13
    Re: Cake stand
    'Tis nice.
    Can you eat directly off copper?
  19. #14
    Mar 2008
    Georgetown, Texas
    Re: Cake stand
    That's going to be a sight to see with a cake on it. It looks just super and your wife(to be) will just love it.
  20. #15
    Mar 2004
    hueytown, ala
    Re: Cake stand
    well just for decoration and a pretty cake a 12-9-6 will do... little small but you could get your baker to bake sheet cakes and serve from the kitchen... or if a small gathering what you have might be enough... good luck... biggest we ever dealt with was a 5 tier with an 18" bottom and proportioned on up.. and it was tiered not stacked . and in the center of a 6' round table on a stand that was nearly a foot tall itself. We couldn't stack it and move it in one piece, way too heavy and too shaky to try to move it to the center and lift it up on the stand My wife is 5'2" and had to stack and trim the top few layers leaning off a ladder with me holding her upright by the belt loops... it took two margaritas to get her settled down after that day !!!
  21. #16
    Jan 2011
    W. Wisc
    Re: Cake stand
    Looks really cool, but I am in the camp of potential structural concerns. Really not much holding that up and i think weight is going to make it want to twist and collapse - corkscrew style. Now the question is how much weight will be on it? A few ounces on the 2 upper tiers and you should be fine, but there will be a point where it is going to want to collapse...the question is how much? Might be worth testing with some weights before you get too far? Even a few tacks should give you an idea if it is sturdy enough or just waiting to fold up on you. Find out how much the cakes will weigh, roughly, and go up from there. Someone will be applying pressure to cut and probably not thinking about needing to be gentle as they are not wondering if it is on the edge of the cliff, so to speak.
    -Dave
  22. #17
    Jul 2018
    Cumbria, UK
    Re: Cake stand
    thanks all, some valid concerns. Don't worry, I'll be making sure it's plenty strong enough.
    I realised last night it was no good in current form. I liked the design as-was, though, with the helix spars wrapping inwards, so what I'm doing is I've ordered some more sheet, and making a bigger base plate (18") and moving the 1st and 2nd levels up one, removing the small 7" top level.
    So I chopped the helix spars off last night. 1 step forward, 2 steps backward, lol
    The plates are currently 7", 10" and 14". I'm going to 18", 14", 10". The wrap-around design robs 4" of practical diameter. This will give plenty room for cutting, etc, which is what I should have started with.
    I may have to do a double helix (opposite direction) to get the strength I need, but piecing in after the first two spars are done is relatively painless. Either way, I need to crack on with it now!
    And yes, of course you can eat off copper, it used to be used all the time in food and water service
  23. #18
    Re: Cake stand
    Every copper thing I have is zinc lined.
  24. #19
    Jan 2017
    Dallas, TX
    Re: Cake stand
    Potable water in my house is piped in copper so should be no worries as to safety.
  25. Likes bubmiller liked this post
  26. #20
    Jul 2018
    Cumbria, UK
    Re: Cake stand
    Do you have copper water pipes? They won't be lined.
    I'm not cooking off it and there will be a base to the cakes anyways!
    Copper poisoning, as a potential problem, is so low down on the list that it's not even there.
  27. Likes Equilibrium liked this post
  28. #21
    Colorado Springs
    Re: Cake stand
    Copper is gud for the artheritus. That and a little remitiz medicine. According to granny Clampet, anyway.
    Lincoln 175
  29. #22
    Re: Cake stand
    Don't forget to account for some drunken lout of a wedding guest trying to cut a piece of cake using his whole weight on the knife blade
    I went to a wedding once, when I was maybe about 21yrs old. A wild one it was.
    They'd set up a grill outside (middle of Winter), and one of the dood's friends was doing the grillin'. (I don't recommend semi outdoor weddings in January...…..beer has a way of goin' thru your system FAST out in the cold)
    Anyways...….you could go inside the house to warm up, but all the pot smokers were holed up in the house, and I'm thinkin' I got a contact high that night.
    There was an open invite to all of the guests to sleep over, bein' as we were all knackered, and it was about maybe 12mi out of town. I wasn't about to sleep in that house...….you couldn't see across the room for all the pot smoke.
    So, I headed home sometime around 3:00 AM. It was a Hellish drive, ice covered highway, and me with tunnel vision (had to be that dam pot smoke) Been a beer drinker all my life, and never before, or after, have I had tunnel vision.
    I get home in one piece...…….THEN IT HIT ME. (Remember the dood runnin' the gril?)
    I saw the sun come up that morning, sittin' on the toilet
    The guy runnin' the grill was too dam drunk to be cookin', and I was too dam drunk to realize I was eating undercooked chicken
  30. Likes Lis2323, Munkul liked this post
  31. #23
    Jul 2018
    Cumbria, UK
    Re: Cake stand
    new base level made, the small 7" level will be put to one side for now
    two spars partly welded. It's not the easiest stuff to weld! Hard enough to get the heat into the mass now, without melting the tube to bits!
    The third spar is just offered up but I need to start again with it, the bend radius isn't quite right and it doesn't match.
    Not far off, now though. It'll be plenty strong enough with a 3rd spar, this copper tube has a lot more tensile strength than pure copper.
  32. Likes psacustomcreations, Equilibrium liked this post
  33. #24
    Fredericksburg, VA
    Re: Cake stand
    This is very nice looking and an interesting use of the materials.
    It gives me ideas on how I can try to use them as well.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  34. #25
    Outside of Raleigh, NC
    Re: Cake stand
    Very cool design and fabrication! Congrats on the upcoming nuptials too!
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
Page generated in 1,634,952,348.15976 seconds with 12 queries
