Page 1 of 4 123 ... LastLast
Results 1 to 25 of 84
Thread: 5460 DV cooler FLOW ALARM !!
    anyone ever have an issue with this flow alarm?
    the cooler is filled to the top and I have water flowing in and out.... but this damn alarm keeps going off.
    first time it's done this in about 4 years...
    I know you can switch it off... but I'd rather figure out why it DO dat.
    Re: 5460 DV cooler FLOW ALARM !!
    Have you "tied up" any of the hoses going to the TIG torch somehow? plastic zip tie?
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    yes,
    actually... but Ive had them zipped for years.... maybe I went tighter this time.... I will look into this... thanks.
    No dice
    I cut the zip tie and it still doing the same thing.
    Like I said itís got flow in/out
    And if you take the top cap off you can see water coming out of the blue tube which I assume is normal.
    Hmm... Ever let the coolant get so dirty that while it may be clean now, perhaps it clogged up the pressure/flow sensor?
    The blue tube is the pressure-bypass, hence doesn't go through the pressure/flow sensor that I know of . So yea, that tube is not the water return into the tank coming from the tig torch. There is a separate hose for that. Time to take off the cover....
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    I was using distilled water with a small bottle of HTP algicide.
    Iím embarrassed to say I havenít changed it in four years...
    Mainly because it looked clean.
    It still did actually.... (visually)
    Anyway I checked all the hoses they were good.
    I took apart the pressure/flow sensor and cleaned it out really good.
    Also flushed out the whole system with vinegar/water
    Water rinse.
    Seems to be normal again.
    I have a feeling that flow sensor is super sensitive ....
    Iím not really a big fan of it anyway.
    Iíd like to replace it with one of those paddle wheel site glasses.
    If I can find one reasonably priced.
    Iím not sure if Iím going to go back to distilled water or RV coolant or what.
    Maybe Iíll just use the distilled water again and change it more regularly.
    My garage is heated so I really donít need antifreeze properties.
    I also find it very odd that HTP puts a flow alarm shut off switch on the front.
    Why would anyone want to shut it off?
    itís there for a reason.... Supposedly
    Even though itís not very accurate.
    Delaware
    I only use water in my HTP cooler. As my shop is heated and I have animals in the shop and don't like antifreeze that may leak and them get into. I had the alarm go off once, disconnected the torch from the cooler and ran the cooler with a bypass hose and it was fine. Blow out the tig torch hoses with air and hooked them back up and its been fine.
    At least ya got it working right again. I suppose people might not want to hear that buzzing sound when they first turn it on each time as it fills the hoses because the baby is in the stroller right next to them sleeping while they TIG weld,
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Southern CT
    Do you mean like this?: https://www.amazon.com/Miller-212745.../dp/B004HECI8M
    It is for a Miller Coolmate 3, same as my Binzel and it is just spliced into the hose. I think if you shop the internet might find the kit for less.
    Ernie F.
    Exactly
    Thank you.
    Yeah,
    Thats right... it does beep for a second when you first turn it on also.
    Not a big deal.
    When I had the cover off just for the heck of it I took the fan blade off to see what it would sound like without the mechanical fan.
    Nice and quiet.
    Looks like thereís plenty of room for an electric computer fan instead.
    But Iím not quite sure how I would wire it/power it.
    I think most of those fans are 12v
    And need a step down transformer ?.
    Maybe someday....
    Iím too busy to think about that right now
    Southern CT
    I was set to buy that cooler but read where the alarm was sensitive, especially with 25' hoses. A lot of the stuff I weld is all around the bench, the hoses get looped, turned etc.
    Those flow indicators do make a little bit of noise. I ran the Binzel with the paddle wheel removed and noticed the difference but not really that much. I rather see the thing spinning.
    Curiously I have a Coolmate 4 and it has no such flow indicators or alarms. Still works fine after about 20 years.
    I also use distilled water in the coolers. I add a couple cap fulls of bleach.
    Ernie F.
    Jun 2009
    Draper, UT
    Yeah,
    Maybe someday....
    Tony's got ya covered
    MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC
    I was set to buy that cooler but read where the alarm was sensitive, especially with 25' hoses..
    You think they sensitive to 25 foot'ers, try 50ft'ers!
    The one I have with the Invertig 221 isn't that sensitive, just normal I guess if you step on a hose, but those are 25ft regular length tig hoses.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Have you ever measured the flow on your HTP cooler?
    How many oz. per minute?
    Feb 2016
    Myrtle Beach
    That's the only issue I have with mine so far is stepping on the hose it goes off for a sec with 25ft lead. I haven't had any issue with getting leads twisted setting it off yet.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
    Quote Originally Posted by Capt B View Post
    Thatís why I asked about the flow rate
    oz per min.
    I donít think these pumps are putting out what some others do.
    I tested mine last night but I donít want to speak before a test it again.
    Iíll tell you this,
    It was NOT 1 quart per minute...
    Which is generally the rule of thumb for tig coolers
    Feb 2016
    Myrtle Beach
    That’s why I asked about the flow rate
    oz per min.
    I don’t think these pumps are putting out what some others do.
    I tested mine last night but I don’t want to speak before a test it again.
    I’ll tell you this,
    When I get a chance I'll check the flow rate on mine as well.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
    What I did was took the cover off and pulled off the top hose.
    That way you donít have to disconnect any torch hoses.
    I assume that would be an accurate reading
    Im getting about 20oz per minute normally
    And 23 oz with the blue bypass hose pinched off.
    The pump sticker says 8L per min.
    Clearly that canít be correct.
    That would be about 281 oz. per minute!
    Iíve got another question...
    What is the purpose of this bypass hose?
    Seems to me all itís doing is choking down the flow and ď bypassing itĒ back into the tank.
    WHY is this needed?
    I have a suspicion that this is the reason why the flow rate is low.
    Any thoughts?
    Iíve got a good mind to cut it out and eliminate it.
    ALSO.
    Dec 2003
    Fairfield,CT
    Interesting thread. You make me want to check the flow of my Pro-con pump. I know what the pressure is but not the flow.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
  25. #25
    Iíve always read that 32 ounces per minute is pretty much the standard.
    Iím just not understanding this bypass hose....
    Seems to me there is a large percentage of water coming through that bypass hose
    And in the meantime Iím nowhere near 32 ounces per minute.
    All that said,
    Iíve never had a problem with this CK20 torch ....
    The only reason I started to get curious is when this ďflow alarm ď
    Started barking.
Page generated in 1,628,045,595.93369 seconds with 13 queries
