I have a Dayton 3Z812 Bandsaw that Ive been learning about. I cannot find an owners manual online so its one step at a time on the job learning. I finally was able to track a new blade and it cuts great. With one issue. Lets say Im cutting 2 by 3 tube , about 3/4 of the way through the blade stops. If i lift it a tad it goes back to running. Its as if it binds at that point. I took the cover off the gear box and watched it as I cut and it began to smoke about the time it stops....There are no obvious bearings and if I turn the pulleys by hand they both turn nicely, no real resistance.
And to add to the mystery, I can run it horizontally with no cutting, just let it run and it will go forever with no heat generated or smoke.
Any help or observations would be greatly appreciated!!
