Results 1 to 23 of 23
Thread: Gate build help
    Apr 2019
    Gate build help
    Hi all. I am needing to rebuild my double driveway gate, and I am tired of doing it out of wood.
    My question is about the thinkness of steel needed for the box frame.
    The gates will be roughly 6 feet tall by 6 feet wide each. I was thinking that I could use 1.5” x 2” tube, but I am conflicted on wall thickness to use. Should I go with .083 or .120?
    I am attaching the gates to a 6x6 wooden post, so that’s another dilemma that I will have to contend with.
    Also I want to fill in the box frame with wood boards, so that will add a bit of weight, hence the dilemma about wall thickness of the steel.
    Any help will be appreciated.
    Re: Gate build help
    .083 would be sufficient. Are you putting wood on the frame? Or are you building a steel gate?
    If the post have held up with wood, then the will hold up with a similar steel design. Depending on design, the steel will likely be lighter than the wood.
    Apr 2019
    Re: Gate build help
    Thanks for the reply. I am going to inset the wood into the box frame and sammich it between two pieces of 3/4 angle iron. The outside angle will be welded to the face of the frame, and the inside will be screwed in. In case a board needs to be replaced.
    Mar 2008
    Georgetown, Texas
    Re: Gate build help
    Use 2" sq. x 14 ga. square tube. It's light but very strong and square tube tends to be much cheaper than rectangular tube.
  5. Likes davidpuddy, farmersammm liked this post
  6. #5
    Apr 2019
    Re: Gate build help
    Thanks for that tip, Bob. I’ll look at that instead.
  7. #6
    Southern California
    Re: Gate build help
    I second the 2" square 14g choice. Here in southern california (no freezing) I'd even go down to 16g depending on the situation.
    2x2 square tube can be bought in small quantities cheaply through facebook marketplace, offerup, craigslist, etc. in this area from fence/gate companies - YMMV though. 2" square is VERY common and usually a little cheaper (per pound).
    The battle with gates is usually the support posts/hinges - especially if you live in an area where it gets below freezing. feel free to ask any questions you may have and best of luck
  8. Likes davidpuddy liked this post
  9. #7
    Apr 2010
    Re: Gate build help
    davidpuddy
    I have read the thread -
    'you are done with with wood' -
    'steel box frame . . . how thick' -
    'attach to wood posts' [dilemma/how] -
    'fill in the box frame with wood' . . .
    'a bit of weight' . . .
    Put down the Ouija Board
    These issues you know about - consider, 'spinning the telescope' - and starting 'with the Last Part First'.
    The LPF is two fold - how well the gates work - and the caliber/aesthetics of construction [both inside and out].
    Design: the look first, engineer the frame [via standard tube] to carry the look - eg. recess and shoulder . . .
    Fast Forward - the paramount failure with gates are anchor point - both wall and post . . . falling over . . .
    If you have indefatigable anchors - you can massacre the 'look & weight' - because, it will work for infinitum . . .
    Your project is rife with unanswered 'details' - start here . . .
    https://www.google.com/search?safe=a...4dUDCAw&uact=5
    'Spinning the Telescope' - and finding Last Part First - insures success . . .
    hth
    Opus
    ps - P.W. ^ ^ ^
  10. Likes davidpuddy liked this post
  11. #8
    Feb 2019
    Snyder TX
    Re: Gate build help
    A lot of the gates I build will have a heavier piece of tubing on the hinge side. Light tubing for the other end, top & bottom. No reason that all 4 side have to be the same thickness, hinge side needs a little more beef.
  12. Likes thegary, davidpuddy, oldfartrr, bigcreek liked this post
  13. #9
    Mar 2008
    Georgetown, Texas
    Re: Gate build help
    Quote Originally Posted by cwby View Post
    I used to do that as well but gave it up as I decided it wasn't necessary. I use those rectangular hinges and the width lets the weld go all the way to the edges changing the tension to the front and back of the gate and not the end. It has worked well even on quite large gates.
  14. Likes davidpuddy liked this post
  15. #10
    Apr 2019
    Re: Gate build help
    Bob, so instead of bullet hinges I should use regular rectangular weld on hinges?
  16. #11
    Apr 2019
    Re: Gate build help
    One more question...where I attach the steel hinge post to my wood post, should I drill through and do like all thread, or just a long lag screw?
  17. #12
    Re: Gate build help
    If an opener may be added to these gates, then I would suggest 1/8" wall min/doubler plate at the point of attachment and strong hinges And careful proper adjustment of the actuator.
  18. Likes davidpuddy liked this post
  19. #13
    Apr 2019
    Re: Gate build help
    Sorry for the delay. Here is the finished product.
    Just a little touch up paint left. Thanks for all the help.
  20. Likes Flyer58, Capt B, DavidR8 liked this post
  21. #14
    Re: Gate build help
    Looks great
    Quote Originally Posted by davidpuddy View Post
  22. Likes davidpuddy liked this post
  23. #15
    Re: Gate build help
    looks good. What did you learn?
  24. #16
    Apr 2019
    Re: Gate build help
    Learned to always check the steel supplier for deals. I got the steel for the gate at a discount. I had to clean it up as it was pretty rusty, but worth it in the end.
  25. #17
    Re: Gate build help
    Looks good. Thanks for posting up the finished product.
  26. Likes davidpuddy, 12V71 liked this post
  27. #18
    Jun 2011
    Texas
    Re: Gate build help
    Looks great! I was going to suggest that you get pre-primed steel, but never mind..... (-;
    -Ruark
    "Become one with the puddle, grasshopper" - Welding Instructor
    Lincoln 3200HD
    Hobart Stickmate LX235
    TWECO Fabricator 211i
  28. Likes davidpuddy liked this post
  29. #19
    Apr 2019
    Re: Gate build help
    Quote Originally Posted by Ruark View Post
    It was pre rusted....lol
  30. #20
    Re: Gate build help
    That turned out nice.
    You'll find that the gate is stronger than the gateposts. All the leverage is on the posts.
    I do different types of gates, but it's same same.
Size:  140.4 KB 14ga 2x2 with cow panel filler/web. I can stand on the end of the gate, and it doesn't do much. Bends a bit, but springs back. I haven't approached the yield weight/force. 150lbs at 16ft........that's some leverage, and torque. Now, if'n yer a 250lb sack o' fat, yer mileage might vary
    We have a bunch of climb proof gates coming up this Winter. Same overall design, a considerable bit heavier, but with vertical bars only. They should be even stronger. If you have a gate out of sight from the house, you make damn sure it can't be climbed easily. Azzhole hunters like to go on other people's places, and they like to climb gates.
  31. Likes 12V71 liked this post
  32. #21
    Mar 2008
    Georgetown, Texas
    Re: Gate build help
    Not a fan of bullet hinges. I tried to find a picture of the hinge welded in but not very close. I almost always just use 14 ga.x2" square and have never had any problems at all even on fairly heavy gates. And by the way, your gate came out great, really looks good.
  33. #22
    Apr 2019
    Re: Gate build help
    Thanks Bob, I got the steel really cheap, but if I had to pay full price I would definitely go thinner. The tube I used was 1/8”. After I welded the hinges to the post the gate deflected less than 1/16” of an inch, so all is well that ends well.
  34. #23
    Re: Gate build help
    Some of the best hinges I ever used were made by cutting big roller chain( #160 or #240) between the links and welding the two half sections to the gate and post.
Page generated in 1,638,683,589.94402 seconds with 13 queries
