Results 1 to 22 of 22
Thread: Cast iron gear
    Aug 2013
    Hudsons Hope BC
    Cast iron gear
    I need help making a decision. I have a cast iron pinion gear from a cement mixer I want to build up the gear teeth.
    This is what I have in my tool box, certanium 889, avesta 2311, I think it is rhe same as 304n , 308-16, 309 in tig rod and flux coated and gas brazing rod
    My go to for cast has always been gas brazing , have not done any arc welding on cast is 25 years.
    As I am trying to build up gear teeth and then grind and file to shape I think I would like a tougher and more work able surface then brass.
    Thanks all
    Scott
    Lincoln 350mp
    miller regency
    miller syncro wave 300
    Re: Cast iron gear
    Is this a differential pinion gear? That certainly isn't cast iron. If it's some other application possibly could be cast iron. Do a spark test to verify. If it is indeed cast iron, I would use 55 nickle rod. What's so bad about brass, that generally wears pretty well if it matches up profile wise and is kept well lubricated .
  3. Likes Insaneride liked this post
    Re: Cast iron gear
    Quote Originally Posted by bcguide View Post
    Thanks all
    Scott
    If you're comfortable with bronze brazing, I think it would be a good choice. The bronze would be easy to form and would match the cast iron in wear properties.
  5. Likes ronsii, shortarc liked this post
  6. #4
    Aug 2013
    Hudsons Hope BC
    Re: Cast iron gear
    Its a cheap old monarch mixer with a crown gear on the tub and a exposed pinion.
    I have done a spark and drill test it is cast iron.
    I would be better of throwing it away and renting one for a couple of days but 1, it is a 100 mile round trip to rent one and 2. It would deprive me of the fun of fixing it
  7. Likes ronsii, 12V71 liked this post
  8. #5
    Re: Cast iron gear
    Brass has the closest properties to cast iron except when high heat is introduced such as an exhaust manifold. Get a tiger torch or make a little furnace and braze it. Brass won't be too hard to grind and file to size and is the preferred way to repair cast iron in most cases.
  9. #6
    Soda springs,Id
    Re: Cast iron gear
    Is there a chance you can shim the drum hub to move it closer to the pinion?
    Mike
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  10. #7
    Aug 2013
    Hudsons Hope BC
    Re: Cast iron gear
    No I would have to grind down the hub and think it would be easier to build up the grear.
    I'm going play with it this afternoon.
  11. #8
    Soda springs,Id
    Re: Cast iron gear
    Well, it was just a thought.
    Mike
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  12. #9
    Jul 2016
    Midwest
    Re: Cast iron gear
    Thanks all
    Scott
    Many products will "work" for your gear. I like a product called Nickel Silver from Weldcote metals. Great brazing product for steel or cast. It's machinable and then it work hardens when put into service. Just a top notch product. How much build up do you have to do? Maybe I can send you a couple sticks.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
  13. #10
    Re: Cast iron gear
    A pinion I typically make new one out of steel.
    The big gear is typically made cast too and pinion wear faster
    Thanks all
    Scott
  14. #11
    Feb 2012
    Re: Cast iron gear
    What pre and post temps/time does cast need?
    It does need pre heat no?
  15. #12
    Re: Cast iron gear
    Yes, cast iron needs lots of preheat. I think around 800 deg's. if I recall but it's been a long time since I brazed cast iron in school. Look online, there are a few video's of brazing gear teeth. You can wrap it in a fire blanket when done or some guys bury cast in dry sand or Kitty litter to slow cool.
  16. #13
    Aug 2013
    Hudsons Hope BC
    Re: Cast iron gear
    never got to the shop today hope tomorrow works out better.
    Rondo thanks for the offer but I need to get this fixed and mix some cement next week.
    Smith door i would like to know how you would go about building a pinion. If I didn't hate string words together so much we could turn this into farmersam type thread. Let's see id make a dividing head the build a shaper have to go to town have a dinner out buy some 3/4 hss tool steel.... LOL.
    I was serious though I would loke to know how you would go about making the pinion
    Hope I didn't offend you Sam I really do admire your ability to fabricate stuff.
  17. Likes Insaneride liked this post
  18. #14
    Re: Cast iron gear
    Your exactly right, most times you just need to get it working. You never really specified, is this a small mixer with an electric motor? If so you would be doing this on the bench. Fire up a charcoal grill and put it in the coals. Do your brazing then put it back in the coals , close the lid, cover if you can and let the fire burn out. Pre and post heat is not as important when brazing as when welding but it will make it much easier. Good luck with the repair.
  19. Likes Insaneride liked this post
  20. #15
    Re: Cast iron gear
    A few observations.
    First one is partly pointless since I'm retired but when we were casting we used to keep at least 2 different sizes of cement mixer pinion gears in stock. They wear out and they are supposed to. You might inquire from the manufacturer or parts suppliers or maybe a local foundry if there is one around.
    I wouldn't use something hard to rebuild the pinion gear, brazing is good. Consider the job of fixing the pinion gear versus rebuilding the crown gear.
    If anyone has ever lubricated(grease/oil) the crown and pinion on your mixer, take him/her out behind the barn and have a serious conversation. It is meant to run dry, run it that way.
    ---Meltedmetal
  21. #16
    Re: Cast iron gear
    I hate to get into a thread late but in this case I feel I must. If you are going to melt the base metal of the cast iron preheat and post heat are needed. If you are going to braze it ( heat but not melt the base metal) heating is only needed until the brass flows aided by the flux if using O/A. Post heating is not needed, just cover the part and let it lay in an area where there is no air movement . The biggest mistake made when brazing is in the prep. If you grind the area to prep it you smear the carbon around and it makes the brass not want to flow into the casting. If you need to grind it out that is fine but the very last thing you need to do is take a carbide burr to the area to take off the carbon smeared layer of metal. This is true if O/A brazing or tig brazing.
  22. Likes Welder Dave liked this post
  23. #17
    Re: Cast iron gear
    Yes to preheat, slow cool but doesn't need post heat and a carbide burr is the easiest way to clean up any carbon smearing from grinding.
  24. #18
    Jul 2009
    New Jersey
    Re: Cast iron gear
    Coming to the party late so if I missed something, please excuse me. Can you buy a stock gear from a company like Boston Gear that matches what you have and graft on to the shaft? Again, if this was covered already, I missed it and apologize.
    Joe
  25. #19
    Sep 2008
    Louisiana
    Re: Cast iron gear
    A corner or edge needs no preheat or post heat, or tooth in this case. Braze or nife55 which ever you are most comfortable with.
    Good luck.
    Peter
    Equipment:
    2 old paws
    2 eyes (that don't look so good)
    1 bad back
  26. #20
    Aug 2013
    Hudsons Hope BC
    Re: Cast iron gear
    Done, could have spend more time making it perfect but its good enough for this project.
    Meltedmetal thanks for the heads up on using a soft metal.
    Lincoln 350mp
    miller regency
  27. #21
    Apr 2010
    Re: Cast iron gear
    bcguide
    . . . I have a cast iron pinion gear from a cement mixer . . .
    What is the New-Purchase-Price of your machine . . . equipped
    with the same Cast Iron drive-train . . . ?
    Any OEM with a Boston Gear - you buy a new Boston Gear, and
    it is new again . . .
    You have received sage welding / brazing advice. I recommend
    you execute
    [per spec.] - every welding/brazing techniques
    posted . . .
    This exercise is $ futile: but, will produce a wealth of welding
    knowledge - that can only be gained - by doing something that
    isn't worth doing . . .
    Opus
  28. #22
    Re: Cast iron gear
    bcguide
    you execute
    posted . . .
    Opus
    Exactly like reading yet another opus post.🤣
Page generated in 1,634,866,090.81225 seconds with 13 queries
