Results 1 to 25 of 41
Thread: SWAG Off-Road Finger Break Upgrades
    Oct 2013
    Long Island, NY
    Hey guys, thought I’d share a couple changes I made to my swag brake setup.
    When I was in the market for this multiple members told me it’s useless and you can’t do any real bending with any precision with it. And I will say out of the box that was certainly the case. But now it functions as a real tool with a fairly good degree of precision.
    Hopefully this will help other guys out there who don’t have the space or resources for a real brake.
    Before going on I’ll address the main problems with the stock setup.
    #1 the die (formed of 3” angle) requires nearly a 4” minimum piece to be able to catch both lips of the die for bending.
    #2 It is very hard to gauge spring back with such a grossly exaggerated air bend due to problem #1
    #3 it does not create tight radius bends again due to problem #1
    #4 the hydraulic jack takes forever to use by hand.
    So the first thing I did was convert the press to air over hydraulic. I chopped off the mounting plate for the stock jack and made a new one to fit the air jack. Then I converted the switch to a foot pedal so I could work with both hands while simultaneously adding pressure.
    The next thing I did was purchased the “flat top” add on from SWAG for $140. This is supposed to address the problems above. It was a waste of money. It is completely worthless and makes horrible uneven bends because it essentially floats on top of the fixture and does not self align to the blade of the brake. It’s a complete disaster.
    So the solution was making a stackable die out of 1/4” steel which i drew to have a flat alignment at the top to support the work. They were CNC cut and bent in place on tbe press. After this change i was able to use the press to make bend down to avoid 3/4” stickout with a tight radius.
    On the smallest die i can bend up to 1/4” steel about 8” long.
Size:  133.8 KBName:  A3F67EA1-4701-408C-BB91-5B831CB99C02.jpg
Size:  57.7 KBName:  36DFD074-DB7F-4F8F-933B-F9457678A5C7.jpg
Size:  109.5 KBName:  72F6EAF0-A8CF-4648-B063-C4D09579301A.jpg
Size:  108.2 KBName:  11243C7F-DAE4-4EE5-8074-0BCCE70B876C.jpg
    www.FirehouseFabricators.com
    Zach
    Millermatic 255
    Lincoln SW200
    Hypertherm Powermax 45xp
    2x4 CNC Plasma Table.
    Oct 2013
    Long Island, NY
    Re: SWAG Off-Road Finger Break Upgrades
    Here’s a couple recent bends for my plasma table project.
Size:  125.6 KBName:  29225A48-DAA9-40A8-9468-C58426DF6182.jpg
Size:  115.8 KBName:  E57BFF8A-CC3E-4F65-B740-9A9A72288990.jpg
Size:  117.7 KBName:  EEA4EB47-9027-4BF2-800B-08F7699B13CE.jpg
Size:  97.2 KBName:  DFCF143D-3A1F-47C1-99F5-EB35EE643238.jpg
    Zach
    Millermatic 255
    Lincoln SW200
  3. Likes whtbaron, Munkul, arcflash liked this post
    Feb 2016
    Myrtle Beach
    Thanks, I have one that I use a good bit but have a lot of the issues you mentioned above. I am going to copy your idea for sure.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
    Oct 2013
    Long Island, NY
    Quote Originally Posted by Capt B View Post
    I can send you the file for cutting if you like. I drew it in 20 40 and 50 inch length.
    Zach
    Millermatic 255
    Lincoln SW200
  6. #5
    Feb 2016
    Myrtle Beach
    That would be great!
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  7. #6
    Dec 2015
    You should make and sell your solution as an add-on kit....
  8. Likes wb4rt liked this post
  9. #7
    Sep 2008
    Dalton, GA
    I would like the file for the 20” pieces.
    I agree on you making and selling these. Shipping may be an issue but better than trying to source locally for a one-off order.
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 140
    www.10FtDrillBit.com
  10. #8
    Nov 2019
    North East Ohio
    Im headed out the door. I need to look at this post.
  11. #9
    Oct 2013
    Long Island, NY
    Quote Originally Posted by Dee_veloper View Post
    I sold the file to probably 25 people for $5 and sold a couple kits for the 20” for $100 shipped.
    It isn’t really worthwhile to me other than some gas money.
    Zach
    Millermatic 255
    Lincoln SW200
  12. #10
    Dec 2015
    Most enterprises start small. SWAG didn't begin with a corporate scale operation either...
    Anyway, thanks for sharing.
  13. Likes VaughnT liked this post
  14. #11
    Nov 2019
    North East Ohio
    I too would like a file. I will send you a private message. I use my brake frequently on my gym equipment builds. it clearly has its limitations. I need to reread the air hook up. I like that.
  15. #12
    Seward, Ak
    I inserted other 1/4" angle iron pieces in a similar manner.
  16. #13
    Dec 2014
    Northern California
    Great post OP...very helpful with my plans for a press....
  17. Likes whtbaron liked this post
  18. #14
    Nov 2019
    North East Ohio
    What is the part numbers for the H.Freight air system?
  19. #15
    Aug 2020
    Does it work well, I imagine once you stack them they stick out past the original edge?
    Also what sizes did you use ?
  20. #16
    Oct 2013
    Long Island, NY
    Quote Originally Posted by digitalmonk View Post
    They’re designed to stack with a flat surface across them.
    Zach
    Millermatic 255
    Lincoln SW200
  21. #17
    Apr 2007
    Portland, OR
    Would you sell another 20T set?
    Miller Syncrowave 180SD
  22. #18
    Aug 2021
    I would take a set of the 20”
  23. #19
    Jan 2012
    I tried to tell SWAG that their bender needed something like this. They sold me that stupid thing that goes on top. The above is fantastic. Wish I had them.
    Primeweld Cut 60 Plasma Cutter
    Millermatic 211
    Lincoln Precision TIG 225
    Century 250 MIG
    Lincoln 225 AC Box (sold)
    I support my local welding store (Amazon, McMasterCarr, Cyberweld, EBay). Yes it's sarcasm.
  24. #20
    Oct 2013
    Long Island, NY
    Quote Originally Posted by Fab54 View Post
    I bought the top piece and its the biggest waste of $120 I ever spent.
    Zach
    Millermatic 255
    Lincoln SW200
  25. #21
    Southern California
    Most of their stuff is extremely over priced IMO (disclosure: I am cheap so it could be me), but they do fill a market need.
    There really aren't many viable alternatives to their stuff, which seems strange.
    Though it is a bit niche I would think if harbor freight makes enough money to still sell the base tools (hyd. press, tube roller) They would also profit from selling the accessories (dies, metal brake attachment, etc).
  26. Likes oldfartrr liked this post
  27. #22
    Jan 2022
    Found this while looking for a solution to make my SWAG brake workable. I'd love to get a copy of this file if its still available.
  28. #23
    Aug 2022
    Bringing this thread back to life lol does anyone have the file for those 20” dies? I just picked up one of these and would love to bend a tighter radius
  29. #24
    Apr 2020
    AntHome 92025
    Quote Originally Posted by freedom_fabwerx View Post
    bringing this thread back to life lol does anyone have the file for those 20” dies? I just picked up one of these and would love to bend a tighter radius
    x2 .
    Millermatic 255
    Everlast Typhoon 330
    Ready Welder I
    Hypertherm 30XP
  30. #25
    May 2011
    I have a large press brake, but I was wondering how bad do the corners of the bend angle dies dig into to the metal your bending?
    My press brake uses tool steel dies with rounded edges. But im asking because I'm interested in building this type of setup for misc jobs.
Page generated in 1,713,243,070.08479 seconds with 20 queries
