Results 1 to 12 of 12
Thread: Harbor Freight Air Punch/Flange Tool
    Jan 2020
    Magnolia, TX
    I need to do a little work on car floor pans and a few spot welds on various sheet metal parts. This was recommended to me. Has anyone tried it?
    https://www.harborfreight.com/air-pu...tool-1110.html
    Colorado Springs
    Re: Harbor Freight Air Punch/Flange Tool
    A friend of mine uses one on aluminum fly rod cases every day and he love it.
    Sent from my XT1635-01 using Tapatalk
    Lincoln 175
    Monkey Wards 230v. Stick
  3. Likes Flyer58 liked this post
    Apr 2018
    Montana
    Quote Originally Posted by Flyer58 View Post
    I have. We used them in an auto body class I attended last year and they work great.
    It makes things much faster from pans to panels to patches. But one has to acknowledge that it creates that recessed lip (on back normally not visible) so things aren't perfectly flush both outside and inside; just the outside. I suppose someone could always grind it away on the backside after welds are done, but we never bothered with that.
    So in exchange for an "invisible" lip, the ease of a drop-in patch, the thicker welding area, and the less time spent fiddling with butt welding clamps easily made the flange tool a preferred tool for our restorations/repairs.
    I don't know if they even have the old style anymore but the new ones with the flange on one side and the punch on the other makes it perfect for plug welds and joining two sheets together.
    Lincoln 140HD solid .023 and 75/25% Ar/Co2 or 100% Co2
    Lincoln SP-140T innershield .03 or Aluminum spool gun
    Dayton 230A AC Stick
    Harris Oxy/Ace torch setup
    Chicago Electric Stud Welder
    LTP 5000D Lotos 50A Plasma
    Vulcan Protig 205
  5. Likes Flyer58 liked this post
  6. #4
    Jan 2020
    Magnolia, TX
    Thanks! I called the local store today and they're holding one for me. These floor pans are in a Jeep and will be undecoated and sealed over so the seam won't be that visible.
  7. #5
    Dec 2016
    got one yesterday .works fine but trigger plunger was leaking until i cycled it a dozen or so times.
    also,the oring on the oil screw was damaged.
  8. #6
    Big Lake/Monticello MN
    I used one just like it on this Ford.
    Pretty sure I got it at HF years ago, works perfect.
    https://weldingweb.com/vbb/showthrea...irs&highlight=
    Syncro 350
  9. #7
    Apr 2018
    Montana
    Great job on that thread! Yeah, I would NOT want to drill all those holes, the punch works much, MUCH faster.
    Vulcan Protig 205
  10. #8
    Jan 2020
    Magnolia, TX
    Quote Originally Posted by filetobeef View Post
    Well heck, Based on what you experienced I took mine out of the box and found oil around the filler plug. My O-ring was damaged too. I filled it and tried it to see if it leaked and had lots of oil come out with each cycle. I sent an email to HF Customer Service saying this may be a problem since these are two new ones have bad O-rings.
    One the good side I tried it on some 18ga sheet metal and it works very well. I expected more of a bang when punching holes but it was very smooth and quiet. I like it.
    Thanks all!
  11. #9
    Quote Originally Posted by Beeker View Post
    Thanks, that floor was a mess to be sure. Much better now.
    Thanks all!
    I'm sure you'll be happy with it. They work well for what they are intended to do.
    Syncro 350
  12. #10
    Dec 2016
    yes,easy to use and very smooth on both the punch and flanging action.
  13. #11
    Jan 2020
    Magnolia, TX
    I swapped it out today after checking o-ring on the new tool at the store. Tried it out at home and it works great. I add to the Mechanic's Park section as I do the floor pans
  14. #12
    Jan 2020
    Magnolia, TX
    Well I finally got a reply from HF customer service and they said no o-rings are available and return it to the store. Glad I already did and now the one I have one that works very well. Still happy.
Page generated in 1,713,311,513.36474 seconds with 20 queries
