Page 3 of 3 FirstFirst 123
Results 51 to 64 of 64
Thread: Evolution Rage 2 carbide blade sharpened by WD Quinn Saw Co.
  1. #51
    Mar 2007
    MidWest
    Re: Evolution Rage 2 carbide blade sharpened by WD Quinn Saw Co.
    Pics of the blade?
    Its on the saw, but I will take a pic tomorrow and post. To my mind, the saw cuts better than new. They had it pack in a box with some sort of blue elastic protector on the tips. I am sure thankful you posted about W.D.Quinn, and who would have thought they would be on the way to my Dr appointment. Thanks
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Ranger 8 Kohler 20HP
    Victor/Harris O/A
    K 487 Spool Gun
  2. #52
    Mar 2007
    MidWest
    Pics of the blade?
    Here ya be
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Victor/Harris O/A
    K 487 Spool Gun
  3. #53
    Mar 2007
    MidWest
    Quote Originally Posted by geezer View Post
    Here ya be
    Oooops, forgot this one
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Victor/Harris O/A
    K 487 Spool Gun
  4. #54
    Laredo + Midland/Odessa
    Blade looks good, geezer! Was that evolution blade 66 or 72 tooth? Looks like a 72.
    I myself just picked two new blades.
    Diablo 90-tooth TCG-tips 14" blade off Amazon for about $90. Works real nice. This will be my go-to blade as I don't use thicker than ¼" steel very often (if I do, I use the plasma cutter).
    The other one I just got is a Tomax 72-tooth 14" blade, also off Amazon, for $61 shipped (it had a $3 coupon ). Figured what the heck, should be ok for a hobbyist. Indeed it is pretty good, runs smooth and true, has a TCG on the teeth just like the diablo. I don't expect for it to last super duper long as the carbide teeth likely aren't commercial grade, but for hobbyist type stuff, it should serve well as a back-up blade to my Diablo 90-tooth (for when I get them re-sharpened), which I plan to order a couple more of.
    I've cut 1/8" thick flat bar (standing up vertically of course) with both and I'm please with how they run. I've been making sure to use wax lubricant whenever I do cuts, so hopefully that habit that I'm forcing unto myself will let these blades last even longer. I just bought some Stick Kut wax lubricant since I'm almost out of the tiny Blair rotabroach stick lube, so here's to hopefully lots of smooth cuts.
  5. #55
    Sending in more blades to get fixed sharpened.
    Accidentally dropped and chipped a couple teeth on the Tomax and the Evo multi-material blade that I already had sharpened (it is relegated only for chopping up oak firewood). The other Evo blade was just a spare so it's just getting sharpened.
  6. #56
    Got the blades back from W.D. Quinn. As before, excellent work.
    Two teeth that were replaced on the 72-tooth Tomax blade
    Nice job on the Evo multi-material blade
    Three sharpenings, three teeth replacement, one was 'hammered and tensioned'. $65 + ~$25 shipping.
  7. #57
    Sep 2011
    Jasper TX
    Never mind...
    Owner of Fast Leroy's Bar and Grill
    Liquor up Front, Poker in the Rear
  8. #58
    Apr 2016
    CA
    Does having the blades sharpened decrease the amount of quality cuts the blades make? Does sharpening change the cut curf width?
  9. #59
    I don't think the kerf width is affected as the carbide tips are the same width. As to the number of quality cuts, I wouldn't be able to answer that without sufficient data. At first glance I don't see how the number of quality cuts could be affected, unless the carbide grain was not uniform to begin with.
  10. #60
    Jul 2016
    Midwest
    Good Info. A buddy of mine is a Rep for Evolution so I have several of their saws. A regular chop saw and a slide saw. He gets tired of me mooching blades off him so I'll send in a few to Quinn and have them re-worked.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
  11. #61
    The prices for their services are very reasonable. $25 minimum per order now, so unless it has less than 82 tips to sharpen, it should cross the threshold on even 1 blade.
    W.D. Quinn Saw Price List
  12. Likes Rondo liked this post
  13. #62
    May 2013
    Great thread!
    Has anyone bothered setting up a 'mister' for their cold cut saw? Curious to see if it might extend the life of these blades.
  14. #63
    Mar 2007
    MidWest
    Quote Originally Posted by johnnymg View Post
    Great thread!
    Not me, it cuts well dry and the blades last fairly long for a casual retired guy. Plus the sharpening place is down the road from me. But mail in works fine to.
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Victor/Harris O/A
    K 487 Spool Gun
  15. #64
    Great thread!
    These blades being dry cut, they rotate much faster than true cold-cut blades which go rreeaaallll sssllloooowwwww. Those cold cut blades usually always need coolant and turn only a couple hundred RPM, where as carbide dry cut blades are around 1300 RPMs; too fast to not sling around all that coolant/oil. Just use stick kut wax stick lubricant.
Page generated in 1,713,265,489.59399 seconds with 20 queries
