Results 1 to 6 of 6
Thread: Greetings and a wanted post.
    Jun 2020
    Hello all, I'm new to this forum and am currently an on hold (due to covid) student about halfway through a welding program. The school closed down and we went to online classes but obviously without welding you can not pass normal welding classes. Our instructor was amazing in helping guys who has access to a place to weld at home get going. I myself have a place to weld and a tombstone 225ac but we are on SMAW III and GTAW II so I need to be running 6010 for one thing. My instructor had an ESAB Multimaster 260 he pretty much gave to me, but it's got a bad control board and a bad amp LCD. It'll run stick and you can adjust the amps. In Mig mode however you can not adjust the volts and they are maxed out. You can adjust the wire feed but anywhere below 8 on the dial it cooks the contact tip. Above 8, you're welding with a nickle sized weld pool. In Tig mode all I could do was burn tungsten back with a tiny pool. I called Airgas and they told me ESAB has discontinued the part number PCB1 838182. I am here looking for any leads to anyone who may have one on the shelf OR a for parts unit. In my searching I found a listing from an auction just 3 years ago where someone in Lansing KS bought 7 non-working units. Pictured below. Of course these sites don't tell you who won the auction. But maybe a guy on here knows a guy?? Any help getting me welding would be greatly appreciated. Thank you!
    Jul 2016
    Midwest
    Re: Greetings and a wanted post.
    Quote Originally Posted by O'Shell View Post
    Try Midwest Welding Eq Repair 419 953-5964 OR Arc source Midwest 515 261-4610 OR DCF Services 507 285-9652 Good Luck !
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
    Jun 2020
    Will do tomorrow, Thank you!!
    Feb 2019
    Snyder TX
    Also check with Innovat Corp. they may be able to help.
    https://innovatcorp.com/
    May 2010
    Sparks, NV
    Quote Originally Posted by cwby View Post
    X2. They repaired a board for an old ESAB for me and did a good job.
    Apr 2021
    Alabama
    Covid had just started when I was in welding school. We argued with the dean that the U/V and Infrared light from welding would sterilize any virus or bacteria in our lab area, so we were the only class that was able to continue while the rest of the school was shut down.
    Andy
    ESAB 350 MPI
    ESAB 330I CVCC
    Lincoln Idealarc 250
    Eastwood TIG 200
    Hobart Ironman 240
    Hobart Plasma Cutter
    Lincoln 110v MIG
    CH 110v MIG
    MK Industries Cobramatic with Prince XL
    Miller XR Wire Feeder
Page generated in 1,713,286,769.94168 seconds with 19 queries
