Results 1 to 18 of 18
Thread: Recumbent trike.
    Jul 2020
    Recumbent trike.
    Here’s annother hobby of mine, building recumbents trikes, this is my latest effort, my eighth.
    Some specs:
    Frame is made from 32mm square tube,
    Swinging arm is 35x 20mm rectangular tube,
    MTB shocky,
    Nine suspension settings,
    Hydraulic disc brakes, 27 gears,
    Tank steering,
    Acherman steering,
    Centrepoint steering,
    Adjustable toe in,
    Two degree camber, t
    Two degree caster,
    20" front wheels,
    700c rear wheels,
    Weight 19kgs,
    Delrin chain guides,
    Wheelbase is 120cms,
    Track is 79cms,
    Shimano Deore cycle parts.
    Frame was stick welded. Unfortunately, my hands and fingers are pretty useless these days so my welding suffers due to not being able to hold the handpiece properly and locked wrists. That's my excuse anyway.
    Idlers, kingpin bushes and steering arm bushes are all frocm turned down Delrin. Chain ibs about 2.5 chains long. Rear suspension has nine evenly spaced settings. Shifters have been reversed, left to right and right to left as my fingers don't work too well anymore. The steering has been geared up to make it stable at speed, this of course increases the turning circle, but, tight enough to turn in a traffic lane. Steering tie rods are mounted with 6mm tie rod ball ends. Tie rod has been threadned with a left and right hand thread to simplify adjustment. All in all I'm quite happy with the trike, it's incredibly comfortable, handles extremely well and if I was 55 years younger would be very fast.
    Jul 2020
    Re: Recumbent trike.
    For those that don't know, recumbents were banned from bicycle racing back around 1930, they were simply too fast for diamond frames. This is my eighth trike build, I've also built three two wheel recumbents, now they are fast! I built one before my last trike build but had trouble getting on the thing, kept falling off and injuring myself. At 70 i don't heal too fast now.
    Jul 2020
    I don't use jigs to build, as is the norm. Nor do I copy designs. I design, sketch out on large cardboard sheets and cut and weld pieces together by hand, using digital protractors, engineers squares and so on. The seat for example was made by getting the wife to trace the shape of my back onto a sheet of cardboard. I then bent and twisted two sheets of 3mm aluminium to provide lumbar support and comfort. So comfortable and form fitting I did away with padding.
  4. Likes frieed, whtbaron liked this post
    Jul 2020
    More pics.
  6. #5
    Nice. I like the design. Seems simple. Is that your design or did you buy plans? How does it ride? What type wheels are on the front?
    I have made a couple of recumbent bikes and an upright bike.
  7. #6
    Jul 2020
    I design my own trikes, this being the eighth. Wheels are 20" with BMX tyres. Handles superbly and its extremely comfortable.
  8. #7
    Awesome. Where did you get axles for the bmx wheels?
  9. #8
    Are you using standard steel ? How does the delrin hold up? I have done roller blades wheels.
  10. #9
    Are all your trikes different? Are you refining as you build? Looks like some critical bending and cutting on the turning assembly. Is that standard or do you create it each time?
    Anyway, very nice. I like bikes, just have not had time to make any more.
  11. #10
    Jul 2020
    Yep, lots of experimentation. I've posted pics of my last 7 builts and a couple of two wheelers I also made. Don't have any pics of builds before the red. The pics of trikes are in order of build.
    I've tried, joystick, hub, uss and tank steering, tank is by far the best. Also experimented with seat height, seat placement, seat shapes and material, chassis design and materials, track, wheelbase, gear trains and so on.
    The red, black, white and grey ones were all made from rubbish I found down the local rubbish dump, the grey one Was in use for over 10 years and saw many, many klms. There was about a 7 year gap between the grey one and the next three when I rode an MTB.
  12. #11
    Jul 2020
    Another two trikes and two two wheels.
  13. Likes whtbaron liked this post
  14. #12
    Used donor bikes are difficult to find since Covid. What did you use for the axles on the front?
  15. #13
    Jul 2020
    Axles were turned down 19mm stock, then drilled through the centre to lighten it up.
  16. Likes whtbaron liked this post
  17. #14
    Jul 2020
    Turned them up on the lathe, 15mm from memory.
  18. #15
    Jul 2020
    Just bright, mild steel tube with 1.5mm walls. I used roller blade wheels on previous builds. Delrin holds up well, it's harder than the rubber on roller blades.
  19. #16
    @toglhot:
    You ever think about building a recumbent that can do stunts/acrobatics... or anything like that??
    I know the bike she is on is not a recumbent but she certainly knows how to make it do whatever she wants
  20. Likes whtbaron liked this post
  21. #17
    Jul 2020
    @toglhot:
    Nope, finished with recumbents, too old now.
  22. #18
    She should consider wearing a helmet. She's high enough up if she fell and hit her head could be deadly. Indian Larry died during a slow speed stand up stunt on a motorcycle he'd done thousands of times. A helmet would have saved his life. One of those things you don't think about until it's too late.
  23. Likes farmall liked this post
Page generated in 1,624,261,761.11192 seconds with 13 queries
