Results 1 to 6 of 6
Thread: HVAC question, sort of
    Sep 2008
    Dalton, GA
    I had to replace my portable dehumidifier when it quit cooling/condensing. I was looking at it and had a thought.
    I was wondering if I could use the fan and cooling coil to make a TIG cooler? It would mean getting the R410A Freon out somehow. Of course I think it quit working because the Freon had already escaped. And I donít know if there is any issues pumping water after Freon. The cooler is a little bigger than necessary and the copper lines are small but seems it would cool sufficiently.
    Anyone tried this or is it a bad idea?
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 120
    10FtDrillBit.com
    Oct 2019
    Australia
    Re: HVAC question, sort of
    If you're talking about the condenser fan and coil from the outdoor unit it should work fine. Just flush with compressed air brake clean fluid or napfa first. Get a refrigeration mechanic to decommission first. Don't try doing it yourself, firstly its illegal and secondly high risk of injury - very high pressure.
  3. Likes Kevin_Essiambre liked this post
    Sep 2008
    Dalton, GA
    Thanks, Woznme.
    To be clear, this is not an outdoor unit, just a small portable dehumidifier. It is rated for 50 pints/day.
    Burt
    Millermatic 211
    Hobart Handler 120
    10FtDrillBit.com
    Oct 2019
    Australia
    Doesn't matter. Still mechanical refrigeration with R410a gas in it. Get a fridgie to recover the gas charge then you can have at it.
  6. #5
    Dec 2008
    Quote Originally Posted by Woznme View Post
    Hey Wozme! Your advice to wb4rt is spot on but your warning of "very high pressure" gave me a little chuckle!
    Every day I work with equipment that can generate 10,000 psi pnuematic pressure and 60,000 psi hydraulic!
  7. #6
    Oct 2019
    Australia
    That's scary high pressure for sure. Most I've dealt with for welding purpose is 4,300psi and I thought that was high. Good thing about it though is that when it's off there's no pressure. Refrigeration systems still have standing pressure when off, in the case of R410a maybe 300psi on a hot day. Plenty of pressure there for the untrained or challenged to have a bad day.
Page generated in 1,624,065,568.63115 seconds with 12 queries
