Page 3 of 3 FirstFirst 123
Results 51 to 57 of 57
Thread: Getting rid of the initial surge/spike/waste of shielding gas. $20 mod. Eazy Peazy.
  1. #51
    Mar 2015
    Re: Getting rid of the initial surge/spike/waste of shielding gas. $20 mod. Eazy Pea
    Just for grins i installed an orifice fitting on the back of my machine. i had to drill it out to #74 wire size to achieve 25cfh from my 50 psi HTP ball type flow meter. Flow should be consistent across a range of pressures because flow "sticks" as soon as it becomes supersonic through an orifice, regardless of pressure. The argon delivery does seem smoother, no rush at the startup. Will do some welding and see if there's any noticeable difference in welding performance.
  2. #52
    Laredo, Tx
    Quote Originally Posted by bakodiver View Post
    How does the float behave when the solenoid opens up? Does it still overshoot the steady-state flowrate you have dialed in, or does it slowly rise to it?
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  3. #53
    Mar 2015
    The ball slowly rises to the flow rate. I did a little aluminum welding and the argon delivery is stable from start to finish, so that's a win. Although i didn't use your idea, Oscar, it got me thinking, and ultimately lead to a win.
  4. Likes Oscar liked this post
  5. #54
    Laredo, Tx
    Glad I could help.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  6. #55
    Apr 2020
    pekin, IL
    I'm gonna try an in-line flow regulator and see how it does.
  7. #56
    Laredo, Tx
    Quote Originally Posted by bplayer405 View Post
    Something like that would be similar to what bakodiver did with the orifice. You'd have to place it very close to the machine as it's just a valve and would eventually let pressure build up in the hose between it and the machine, given enough time.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  8. #57
    Apr 2020
    pekin, IL
    Yep, hose on bottom is a foot away from the welder.
Page generated in 1,624,503,600.54192 seconds with 12 queries
