Results 1 to 3 of 3
Thread: Powercut 1300 Help.
    Aug 2020
    Powercut 1300 Help.
    I was cutting with it tonight it was working like a champ then it stopped. Showed E21 PIP No Continuity. Replaced nozzle and electrode. Checked air at 80 psi. Still does not work. I have air coming out of torch on power on. The air stops and then the E21 code comes back. Anyone have any ideas?
    Thanks,
    Todd
    Jul 2016
    Midwest
    Re: Powercut 1300 Help.
    Quote Originally Posted by Torhino View Post
    Thanks,
    Todd
    PIP is parts in place. Usually means that the consumables aren't seated or tightened properly or, The little plunger safety switch that gets pushed in when the nozzle gets tightened isn't pushed in far enough. Good luck.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
    Ceres, California
    E21, if new tip and electrode in torch don't help.
    Do a continuity check on torch lead. make sure no leads are broken.
    If torch lead is good. then you might be looking at a new pilot arc IGBT.
    Hopefully there is not a problem with the control pcb that drives the IGBT.
Page generated in 1,624,506,874.78024 seconds with 11 queries
